Hi there, I've downloaded Noisex-92 (Matlab M) files from: http://spib.rice.edu/spib/select_noise.html How can I add this noise with the desired SNR (0-20dB) to the signal in Matlab? Thanks
Noisex-92 noises db: how to use it
Started by ●February 2, 2009
Reply by ●February 3, 20092009-02-03
I am not sure what you are having a problem with. For the MATLAB formatted data (a compressed '.mat' file): Download the zipped noise file ex: 'white.mat.gz'. Note that the sample rate (19.98 KHz) may not be what you want; that is a separate issue you may have to deal with. Unzip the 'gz' file to get 'white.mat'. In your MATLAB '.m' file use the command 'load white.mat'. Check the new variables (type 'whos' in MATLAB at prompt). You will have created an array 'white' of noise that you can use in your MATLAB script. Scale the part of the data you want to use and add it to your signal to get the desired SNR. Is how to scale the noise the problem? Dirk DWT wrote:> Hi there, > > I've downloaded Noisex-92 (Matlab M) files from: > http://spib.rice.edu/spib/select_noise.html > > How can I add this noise with the desired SNR (0-20dB) to the signal in > Matlab? > > Thanks
Hi Dirk, Thanks for the prompt reply. I've loaded the factory1.mat into Matlab. Yeah, the problem is how to scale this noise. E.g. I've the original signal x <70000x1>, the factory <4699904x1>. I know how to add the noise to signal x(1:70000)+factory1(1:70000), but I have no idea how to get the desired input SNR of 20,15,10...db Thanks, Serge>Scale the part of the data you want to use and add it to your signal >to get the desired SNR. Is how to scale the noise the problem? > >Dirk >
DTW, You need to decide what is a meaningful definition of SNR for your application. Obviously one definition is, for y(n)=x(n)+factory(n): SNR(y)=10*log10( sum( x(n)^2) / sum ( factory(n)^2) ) but, depending on x(n) and factory(n), this may not give you a meaningful result. If x(n) has long periods of silence and infrequent periods of a larger signal of interest, and the factory noise is essentailly constant power, the SNR(y) number you get with the equation above is not representative of the SNR when the larger signal of interest is present. It would be too dependent on how much of x(n) (duration) has signal of interest. Not a real useful definition for the described x (n). Similar problems arise if the signal of interest can be low level on some intervals and a high level on other intervals, while the factory noise level is essentially constant. The SNR over the two intervals will not be the same, while I think you want one SNR to describe the whole signal y(n). You can see the problem. So again, you need to decide what is a meaningful definition of SNR for your application. Dirk DWT wrote:> Hi Dirk, > > Thanks for the prompt reply. > > I've loaded the factory1.mat into Matlab. > > Yeah, the problem is how to scale this noise. E.g. I've the original > signal x <70000x1>, the factory <4699904x1>. > > I know how to add the noise to signal x(1:70000)+factory1(1:70000), but I > have no idea how to get the desired input SNR of 20,15,10...db > > Thanks, > Serge > > >Scale the part of the data you want to use and add it to your signal > >to get the desired SNR. Is how to scale the noise the problem? > > > >Dirk > >
>DTW, > >You need to decide what is a meaningful definition of SNR for your >application. > >Obviously one definition is, for y(n)=x(n)+factory(n): > >SNR(y)=10*log10( sum( x(n)^2) / sum ( factory(n)^2) ) but, depending >on x(n) and factory(n), this may not give you a meaningful result. > >Similar problems arise if the signal of interest can be low level on >some intervals and a high level on other intervals, while the factory >noise level is essentially constant. The SNR over the two intervals >will not be the same, while I think you want one SNR to describe the >whole signal y(n). >DirkDirk, Thanks a lot for the explanation. It helps a lot! Serge
