Accelerometer and Kalman Filter
Started by arvkr ●February 18, 2009
On Tue, 03 Mar 2009 09:56:40 -0600, arvkr wrote:
>>Case 1: >> >>Your vehicle is sitting perfectly still, and the accelerometer is biased > >>by 1/2 m/s/s. >> >>Case 2: >> >>Your vehicle is accelerating at 1/2 m/s/s and your accelerometer bias is > >>exactly zero. >> >>How do you tell the difference? >> >> >> >>-- >>http://www.wescottdesign.com >> >> > > Yes, i give up on trying to use just accelerometer to estimate position > accurately, kalman or any other filter will not produce the necessary > results. Now say i have a 3d gyro data and 3d accelerometer data and 3d > compass data, how would i go about designing a kalman filter to fuse > information to remove the errors that exist in gyro and accelerometer to > produce accurate estimation of position.?
With those inputs (or, for that matter, just the accelerometer and gyro inputs), you will find that while in theory you now have enough information to find your latitude, (a) you still don't know the longitude without more information, and (b) you need gyros with errors significantly smaller than the Earth's rotational rate to even determine latitude. The task you're trying to perform is called "inertial navigation". It _can_ be done just with gyros, accelerometers, and the occasional astronomical observation -- that's how they used to (and perhaps still do) maneuver long-range nuclear submarines, and it's still (or was until quite recently) the way that they got airliners from point "A" to point "B" over long expanses of water (there's legal reasons why they can't use GPS). But it takes really good sensors. They're expensive, and the fact that they're known as "strategic grade" in the biz might give you a clue of how thrilled the US State department would be if you were to export one out of the US. Normally this is done by backing up the inertial measurements with GPS or other radiolocation measurements -- what's holding you back from that? -- http://www.wescottdesign.com
>other radiolocation measurements -- what's holding you back from that? > >-- >http://www.wescottdesign.com >
For the project i am working neither can i use GPS nor i have other measurements, the challenge is to find out if a Dead Reckoning system with accelerometer, compass and gyro will be good enough to estimate the position somewhat accurately ( equal to GPS or slightly less accurate, if its more accurate even better).
On Tue, 03 Mar 2009 12:00:13 -0600, "arvkr" <krarvind@gmail.com> wrote:
>> >>Normally this is done by backing up the inertial measurements with GPS or > >>other radiolocation measurements -- what's holding you back from that? >> >>-- >>http://www.wescottdesign.com >> > >For the project i am working neither can i use GPS nor i have other >measurements, the challenge is to find out if a Dead Reckoning system with >accelerometer, compass and gyro will be good enough to estimate the >position somewhat accurately ( equal to GPS or slightly less accurate, if >its more accurate even better).
North, east, and down are easy (for an arbitrary definition of "easy"); so is latitude. Find the local compass declination and that should suggest a longitude. Only a few more measurements would be needed to resolve any remaining ambiguity. Making a real system that's capable of doing this would be ... challenging. -- Rich Webb Norfolk, VA
Tim Wescott wrote:
> The task you're trying to perform is called "inertial navigation". > ... it's still (or was until > quite recently) the way that they got airliners from point "A" to point > "B" over long expanses of water (there's legal reasons why they can't use > GPS).
... Can you enlarge on that, please? Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
On Tue, 03 Mar 2009 14:23:44 -0500, Jerry Avins wrote:
> Tim Wescott wrote: > > ... > >> The task you're trying to perform is called "inertial navigation". >> ... it's still (or was until >> quite recently) the way that they got airliners from point "A" to point >> "B" over long expanses of water (there's legal reasons why they can't >> use GPS). > > ... > > Can you enlarge on that, please? > > Jerry
What I'm about to say is very approximate -- I haven't kept up on this particular debate. If you really want to know, go digging on the web and the FAA web site for the appropriate press releases. Anyway: There are a variety of concerns about the reliability of GPS. The show- stopper used to be that the DoD gave absolutely no guarantee that it wouldn't shut down the civilian-accessible channels any time it felt like denying would-be opponents the service. That's never happened in practice -- the closest that they came was in Iraq I, but since they couldn't supply our own troops with mil-spec GPS units* they didn't want to cut it off from our guys (who were buying civilian units). Since then the DoD has started fielding satellites that can shut it down on a region-by-region basis, so if it ever does get around to buying handheld mil-spec units it would, for example, be able let things go dark for Iraq III**. So that's not as much of a concern -- but there is still some uneasiness about civilian flight safety depending on military whim. The last time I looked the FAA was wavering, but I don't know if they've caved in and allowed combination GPS/INS solutions in lieu of the much more expensive pure-INS solution. * Makes you wonder -- Rome ca. 300, US ca. 2000; the difference is??? ** Just wait... -- http://www.wescottdesign.com
On Tue, 03 Mar 2009 13:57:00 -0500, Rich Webb wrote:
> On Tue, 03 Mar 2009 12:00:13 -0600, "arvkr" <krarvind@gmail.com> wrote: > > >>>Normally this is done by backing up the inertial measurements with GPS >>>or >> >>>other radiolocation measurements -- what's holding you back from that? >>> >>>-- >>>http://www.wescottdesign.com >>> >>> >>For the project i am working neither can i use GPS nor i have other >>measurements, the challenge is to find out if a Dead Reckoning system >>with accelerometer, compass and gyro will be good enough to estimate the >>position somewhat accurately ( equal to GPS or slightly less accurate, >>if its more accurate even better). > > North, east, and down are easy (for an arbitrary definition of "easy"); > so is latitude. Find the local compass declination and that should > suggest a longitude. Only a few more measurements would be needed to > resolve any remaining ambiguity. Making a real system that's capable of > doing this would be ... challenging.
This is exactly what I was referring to. Yes, it can be done. With really accurate gyros, really accurate accelerometers, really accurate compasses, and some really accurate maps of magnetic declination and variations in gravity, you can figure out your approximate longitude. But it ain't easy, and it ain't cheap. -- http://www.wescottdesign.com
"easy");
>> so is latitude. Find the local compass declination and that should >> suggest a longitude. Only a few more measurements would be needed to >> resolve any remaining ambiguity. Making a real system that's capable
of
Yes its definitely challenging and it can be costly, i will worry about the cost later. Right now if i have 3d readings from gyro, compass and accelerometer how can i use a kalman filter to give me some version of corrected gyro and acceleration. http://www.ocf.berkeley.edu/~tmtong/kalman.php He is alluding to something similar. I am just trying to understand how to model kalman filter to correct gyro accelerometer readings both of which are affected by a scale, bias and random noise. I do understand this might still not be enough, but as long as the kalman filter doesn't diverge it should be better than the raw reading.
arvkr schrieb:
>>> North, east, and down are easy (for an arbitrary definition of > "easy"); >>> so is latitude. Find the local compass declination and that should >>> suggest a longitude. Only a few more measurements would be needed to >>> resolve any remaining ambiguity. Making a real system that's capable > of >>> doing this would be ... challenging. > > Yes its definitely challenging and it can be costly, i will worry about > the cost later. Right now if i have 3d readings from gyro, compass and > accelerometer how can i use a kalman filter to give me some version of > corrected gyro and acceleration. > http://www.ocf.berkeley.edu/~tmtong/kalman.php > He is alluding to something similar. I am just trying to understand how to > model kalman filter to correct gyro accelerometer readings both of which > are affected by a scale, bias and random noise. I do understand this might > still not be enough, but as long as the kalman filter doesn't diverge it > should be better than the raw reading.
The kalman filter assumes unbiased measurements. So I would try to model the bias explicitely. For example for the acceleration your acceleromator gives you a sum of the correct acceleration and the acceleration bias. Then your state vector needs to carry the real acceleration and the bias and by making the assumption the bias is just additive you can model the bias in your measurement function. Same goes for the gyro. But I have not that much experience in navigation measurements so I do not know what a gyro gives you and how you can convert this data to a velocity with the help of a compass. But do not forget that you need at least one unbiased measurement at the intialization of the kalman filter (for example of the position) to have a chance to correctly estimate the bias.
>The kalman filter assumes unbiased measurements. So I would try to model >the bias explicitely. For example for the acceleration your >acceleromator gives you a sum of the correct acceleration and the >acceleration bias. Then your state vector needs to carry the real >acceleration and the bias and by making the assumption the bias is just >additive you can model the bias in your measurement function. Same goes >for the gyro. But I have not that much experience in navigation >measurements so I do not know what a gyro gives you and how you can >convert this data to a velocity with the help of a compass. But do not >forget that you need at least one unbiased measurement at the >intialization of the kalman filter (for example of the position) to have
>a chance to correctly estimate the bias. >
Back at the kalman filter again. This is what i am trying to do. I have accurate distance measurement and i differentiate it with respect to time twice to get Acceleration. Now i add a scale factor and bias to this acceleration. I am able to recover scale no problem using kalman filter but bias of 0.09mg screws up the filter big time. Any idea what i am doing wrong? My State Variables are x = [acc bias] A = [1 0 0 1] H = [scaleFactor 1] my measurement model i am assuming Measured Acc = True Acc * ScaleFactor + bias u = 0 hence B doesn't matter R = var(acc) Q = lower than R
