Hi All, 1) I want to implement MODEM with 128Kbps at 100Khz with high doppler shift channel. Which modulation technique would be suitable . Whether I can go with OFDM or SC-FDMA? Any suggestions 2) Is it possible to simulate 128Kbps with Matlab Thanks & Regards, Ammankumar.S
OFDM or SC-FDMA
Started by ●March 4, 2009
Reply by ●March 4, 20092009-03-04
On Tue, 03 Mar 2009 20:32:40 -0800, Ammankumar wrote:> Hi All, > > 1) I want to implement MODEM with 128Kbps at 100Khz with high > doppler shift channel. Which modulation technique would be suitable . > Whether I can go with OFDM or SC-FDMA? Any suggestionsDunno. It probably depends on a lot more than you've put down here.> 2) Is it possible to simulate 128Kbps with MatlabAs long as you don't mind not being in real time, you can simulate 128Gbps in Matlab. -- http://www.wescottdesign.com
Ammankumar schrieb:> Hi All, > > 1) I want to implement MODEM with 128Kbps at 100Khz with high > doppler shift channel. Which modulation technique would be suitable . > Whether I can go with OFDM or SC-FDMA? Any suggestions > > 2) Is it possible to simulate 128Kbps with Matlab > > > > Thanks & Regards, > Ammankumar.SOFDM will be more sensitive to doppler shifts than a single carrier system when assuming the same symbol bandwidth. But just like already stated this is influenced by a whole lot of more issues than just the modulation scheme like forward error correction, the way you shape the spectrum of your single carrier system etc.
Ammankumar wrote:> Hi All, > > 1) I want to implement MODEM with 128Kbps at 100Khz with high > doppler shift channel. Which modulation technique would be suitable . > Whether I can go with OFDM or SC-FDMA? Any suggestionsWhatever you do, you will be f...> 2) Is it possible to simulate 128Kbps with MatlabNot for you. VLV
Reply by ●March 5, 20092009-03-05
1> OFDM and SC-FDMA are almost identical except for DFT pre-coding done in the later. The only additional benefit you get in SC-FDMA is low PAPR. The only downside is additional FFT stage. Regarding doppler shift. Both OFDM and SC-FDMA are bad with high doppler. What we need to know is the bandwidth rather than the carrier frequency. From that we can calculate the sub-carrier spacing based on the data rate you wan't to support. The receiver is simplified if the doppler shift is substantially less than the sub-carrier spacing. 2> Nobody does real-time simulation with matlab. So whether it is 1 Kbps or 1 Gbps, it really doesn't matter. Regards Piyush
On Mar 5, 12:03�am, piyushk...@gmail.com wrote:> 1> OFDM and SC-FDMA �are almost identical except for DFT pre-coding > done in the later. The only additional benefit you get in SC-FDMA is > low PAPR. The only downside is additional FFT stage. Regarding doppler > shift. Both OFDM and SC-FDMA are bad with high doppler. What we need > to know is the bandwidth rather than the carrier frequency. From that > we can calculate the sub-carrier spacing based on the data rate you > wan't to support. The receiver is simplified if the doppler shift is > substantially less than the sub-carrier spacing. > 2> Nobody does real-time simulation with matlab. So whether it is 1 > Kbps or 1 Gbps, it really doesn't matter. > > Regards > PiyushSC-FDMA makes sense when you do multiple access to lower the PAPR. If it is only for one to one communications, ofdm should be the choice. Or, you can even simply transmit in the time domain and use equalizer (such as viterbi) at the receiver side, which should give you the optimal performance.
