hello forum. convolution between the function x(t), with units of Volts, and h(t), the system impulse response. h(t) needs to have units of inverse time, in order for g(t), the output of the convolution, to have units of Volts: g(t)=summation {x(tau)*h(t-tau)}dtau Correct? 2) If correct, take the signal exp(i*theta) theta has units of radians. If theta=(2*pi)*rand(N)-pi (unif noise distribution btw -pi and pi) The convolution between theta and the gaussian filter h(t) is: theta_new= summation {theta(tau)* h(t-tau)}dtau h(t) is normalized and has units of inverse time (due to the units of the standard deviation). Is it true that theta needs to be divided by delta_t before performing the convolution? (delta_t being the sample spatial distance). thanks fisico30
impulse response units
Started by ●March 4, 2009
Reply by ●March 4, 20092009-03-04
On 4 Mar, 17:56, "fisico30" <marcoscipio...@gmail.com> wrote:> hello forum. > > convolution between the function x(t), with units of Volts, and h(t), the > system impulse response. > h(t) needs to have units of inverse time, in order for g(t), the output of > the convolution, to have units of Volts: > > g(t)=summation {x(tau)*h(t-tau)}dtau > > Correct?How is this relevant to DSP?> 2) If correct, take the signal exp(i*theta) > theta has units of radians. > If theta=(2*pi)*rand(N)-pi � �(unif noise distribution btw -pi and pi) > > The convolution between theta and the gaussian filter h(t) is: > > theta_new= summation {theta(tau)* h(t-tau)}dtau > > h(t) is normalized and has units of inverse time (due to the units of the > standard deviation). > > Is it true that theta needs to be divided by delta_t before performing the > convolution? (delta_t being the sample spatial distance).It seems your question has more to do with mathematical physics than DSP. Check out a newsgroup on physics or read up on Green's functions. Or both. Rune
>On 4 Mar, 17:56, "fisico30" <marcoscipio...@gmail.com> wrote: >> hello forum. >> >> convolution between the function x(t), with units of Volts, and h(t),the>> system impulse response. >> h(t) needs to have units of inverse time, in order for g(t), the outputo=>f >> the convolution, to have units of Volts: >> >> g(t)=3Dsummation {x(tau)*h(t-tau)}dtau >> >> Correct? > >How is this relevant to DSP? > >> 2) If correct, take the signal exp(i*theta) >> theta has units of radians. >> If theta=3D(2*pi)*rand(N)-pi =A0 =A0(unif noise distribution btw -piand = Hello Rune, sorry, I thought it would be a scaling issue that can give the wrong computational results . I found that some people you might be right....... thanks>pi) >> >> The convolution between theta and the gaussian filter h(t) is: >> >> theta_new=3D summation {theta(tau)* h(t-tau)}dtau >> >> h(t) is normalized and has units of inverse time (due to the units ofthe>> standard deviation). >> >> Is it true that theta needs to be divided by delta_t before performingth=>e >> convolution? (delta_t being the sample spatial distance). > >It seems your question has more to do with mathematical >physics than DSP. Check out a newsgroup on physics or read >up on Green's functions. Or both. > >Rune >
On Mar 4, 1:30�pm, Rune Allnor <all...@tele.ntnu.no> wrote:> On 4 Mar, 17:56, "fisico30" <marcoscipio...@gmail.com> wrote: > > > convolution between the function x(t), with units of Volts, and h(t), the > > system impulse response. > > h(t) needs to have units of inverse time, in order for g(t), the output of > > the convolution, to have units of Volts: > > > g(t)=summation {x(tau)*h(t-tau)}dtau > > > Correct?yes it is. we've had both conversations and some little spats about this in the past. since a pair of wires is a possible LTI system that maps an input voltage to an output, the Dirac impulse function has, for its "dependent variable" reciprocal time also. the dimension of delta(x) is the reciprocal of the dimension of x.> How is this relevant to DSP?it's only relevant if you are expecting to sample continuous-time signals to discrete-time and/or reconstruct discrete-time signals to continuous time and want to understand the net, overall transfer function (or equivalently the impulse response). nobody doing DSP ever considers about such issues.> > 2) If correct, take the signal exp(i*theta) > > theta has units of radians.measuring angle in radians is actually both unitless *and* dimensionless. it's arc length over radial arm length. just a number. however, measuring angle in degrees is not unitless, but it is still dimensionless.> > If theta=(2*pi)*rand(N)-pi � �(uniform noise distribution btw -pi and pi) > > > > The convolution between theta and the gaussian filter h(t) is: > > > > theta_new= summation {theta(tau)* h(t-tau)}dtau > > > > h(t) is normalized and has units of inverse time (due to the units of the > > standard deviation). > > > > Is it true that theta needs to be divided by delta_t before performing the > > convolution? (delta_t being the sample spatial distance).i think you need to be a little more clear with the question. as best as i can tell from what you have said so far is if theta_new and theta (tau) share the same dimension (which appears to be the "dimension of unity" a.k.a. "dimensionless"), then h(t) must be the reciprocal dimension of tau (because the dtau has the dimension of tau) and no other division by the dimension of tau is necessary (or correct). r b-j
