Parks-McClellan FIR Filter
Started by mike2108 March 23, 2009
Hi,
I have a question regarding filter coefficients for a Parks-McClellan
filter.
I'm trying to write a simple software loop for the filter using its
difference equation, but I've noticed a difference between the number of
taps.
For, say, a ten tap FIR filter designed using a Hamming window, there will
be eleven filter coefficients C0, C1,...C10
which mulitply by the filter inputs x(n) to get an out y(n) like so:-
y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-10)*C10
For a tenth order filter designed using the Parks-McClellan method I get
ten coefficients C0 - C9. So what I'm assuming is that the way to go is the
following:-
y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-9)*C9
Is this correct?
On Mon, 23 Mar 2009 12:17:50 -0500, "mike2108"
<michealhoran@hotmail.com> wrote:
>Hi, > >I have a question regarding filter coefficients for a Parks-McClellan >filter.
Parks-McClellan is an algorithm for determining filter coefficients given some input constraints. I think you mean you have a FIR filter designed using Parks-McClellan. Just a nit.
>I'm trying to write a simple software loop for the filter using its >difference equation, but I've noticed a difference between the number of >taps. > >For, say, a ten tap FIR filter designed using a Hamming window, there will >be eleven filter coefficients C0, C1,...C10 > >which mulitply by the filter inputs x(n) to get an out y(n) like so:- > >y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-10)*C10 > >For a tenth order filter designed using the Parks-McClellan method I get >ten coefficients C0 - C9. So what I'm assuming is that the way to go is the >following:- > >y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-9)*C9 > >Is this correct?
Looks right to me. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php
>On Mon, 23 Mar 2009 12:17:50 -0500, "mike2108" ><michealhoran@hotmail.com> wrote: > >>Hi, >> >>I have a question regarding filter coefficients for a Parks-McClellan >>filter. > >Parks-McClellan is an algorithm for determining filter coefficients >given some input constraints. I think you mean you have a FIR filter >designed using Parks-McClellan. > >Just a nit. > >>I'm trying to write a simple software loop for the filter using its >>difference equation, but I've noticed a difference between the number
of
>>taps. >> >>For, say, a ten tap FIR filter designed using a Hamming window, there
will
>>be eleven filter coefficients C0, C1,...C10 >> >>which mulitply by the filter inputs x(n) to get an out y(n) like so:- >> >>y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-10)*C10 >> >>For a tenth order filter designed using the Parks-McClellan method I
get
the
>>following:- >> >>y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-9)*C9 >> >>Is this correct? > >Looks right to me. > >Eric Jacobsen >Minister of Algorithms >Abineau Communications >http://www.ericjacobsen.org > >Blog: http://www.dsprelated.com/blogs-1/hf/Eric_Jacobsen.php >
Thanks very much Eric. Mike
On Mar 23, 1:17&#4294967295;pm, "mike2108" <michealho...@hotmail.com> wrote:
> Hi, > > I have a question regarding filter coefficients for a Parks-McClellan > filter. > > I'm trying to write a simple software loop for the filter using its > difference equation, but I've noticed a difference between the number of > taps. > > For, say, a ten tap FIR filter designed using a Hamming window, there will > be eleven filter coefficients C0, C1,...C10
You appear to be using an 11 point window (nonzero points).
> > which mulitply by the filter inputs x(n) to get an out y(n) like so:- > > y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-10)*C10 > > For a tenth order filter designed using the Parks-McClellan method I get > ten coefficients C0 - C9. So what I'm assuming is that the way to go is the > following:- > > y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-9)*C9 > > Is this correct?
Note Eric's nit.
That's an eleven-tap filter, nor ten.
Because the software does it right.
> Is this correct?
Ten taps is correct. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
Well, you have to be careful talking about the "number of taps" and the
"order".
A first order filter has two taps, etc.
Fred
>mike2108 wrote: >> Hi, >> >> I have a question regarding filter coefficients for a Parks-McClellan >> filter. > >Note Eric's nit. >
Noted
>> I'm trying to write a simple software loop for the filter using its >> difference equation, but I've noticed a difference between the number
of
>> taps. >> >> For, say, a ten tap FIR filter designed using a Hamming window, there
will
>> be eleven filter coefficients C0, C1,...C10 > >That's an eleven-tap filter, nor ten. > >> which mulitply by the filter inputs x(n) to get an out y(n) like so:- >> >> y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-10)*C10 >> >> For a tenth order filter designed using the Parks-McClellan method I
get
the
>> following:- >> >> y(n) = x(n)*C0 + x(n-1)*C1+.....x(n-9)*C9 > >Because the software does it right. > >> Is this correct? > >Ten taps is correct. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533;&#65533; >
>Well, you have to be careful talking about the "number of taps" and the >"order".
>Fred
Thanks very much for the replies, I'll be more careful in future.
