Hi all, I am developing a c program under Code Composer Studio v3.3.38.2. It worked well until I used this function: DSPF_sp_biquad. I included the header file (DSPF_sp_biquad.h), but seems it is not enough. This function is defined in the SPRU657B library. Do anyone how to solve it? The message I got is: "Code Composer Studio could not locate: DSPF_sp_biquad.asm Would you like to browse for it?" Thanks, Jordi
DSPF_sp_biquad.asm
Started by ●March 27, 2009
Reply by ●March 27, 20092009-03-27
jalv1039 wrote:> Hi all, > I am developing a c program under Code Composer Studio v3.3.38.2. > It worked well until I used this function: DSPF_sp_biquad. I included the > header file (DSPF_sp_biquad.h), but seems it is not enough. > This function is defined in the SPRU657B library. > Do anyone how to solve it? > > The message I got is: > "Code Composer Studio could not locate: > DSPF_sp_biquad.asm > Would you like to browse for it?"Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. If not, see what library needs to be loaded. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●March 28, 20092009-03-28
> >Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. If not,>see what library needs to be loaded. > >JerryNo, I can't. Moreover, I tested this function in a test program and it works well, I mean it doesn't appear that message. I am not an expert in DSP, so I don't understand why it appears in the main program and not in the test program. Jordi
jalv1039 wrote:>> Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. If not, > >> see what library needs to be loaded. >> >> Jerry > > No, I can't. Moreover, I tested this function in a test program and it > works well, I mean it doesn't appear that message. I am not an expert in > DSP, so I don't understand why it appears in the main program and not in > the test program.This has nothing* to do with DSP. it is a matter of writing code and managing the compiler's resources. Jerry ______________________________ * Well, alright. It's a tool/skill needed to get DSP done, but it isn't DSP. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>jalv1039 wrote: >>> Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. Ifnot,>> >>> see what library needs to be loaded. >>> >>> Jerry >> >> No, I can't. Moreover, I tested this function in a test program and it >> works well, I mean it doesn't appear that message. I am not an expertin>> DSP, so I don't understand why it appears in the main program and notin>> the test program. > >This has nothing* to do with DSP. it is a matter of writing code and >managing the compiler's resources. > >Jerry >______________________________ >* Well, alright. It's a tool/skill needed to get DSP done, but it isn'tDSP.>-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >Ok, but I did the same in both programs and in the test it works properly and in the other it shows the message :S. Any suggestion? Jordi
jalv1039 wrote:>> jalv1039 wrote: >>>> Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. If > not, >>>> see what library needs to be loaded. >>>> >>>> Jerry >>> No, I can't. Moreover, I tested this function in a test program and it >>> works well, I mean it doesn't appear that message. I am not an expert > in >>> DSP, so I don't understand why it appears in the main program and not > in >>> the test program. >> This has nothing* to do with DSP. it is a matter of writing code and >> managing the compiler's resources. >> >> Jerry >> ______________________________ >> * Well, alright. It's a tool/skill needed to get DSP done, but it isn't > DSP. >> -- >> Engineering is the art of making what you want from things you can get. >> > > Ok, but I did the same in both programs and in the test it works properly > and in the other it shows the message :S. Any suggestion?It's not a place I've specifically been. Find out where in your directory heirarchy "DSPF_sp_biquad.asm" is locates and tell the linker -- browse to it -- when it asks. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>jalv1039 wrote: >>> jalv1039 wrote: >>>>> Can *you* locate "DSPF_sp_biquad.asm"? If so, tell the compiler. If >> not, >>>>> see what library needs to be loaded. >>>>> >>>>> Jerry >>>> No, I can't. Moreover, I tested this function in a test program andit>>>> works well, I mean it doesn't appear that message. I am not anexpert>> in >>>> DSP, so I don't understand why it appears in the main program andnot>> in >>>> the test program. >>> This has nothing* to do with DSP. it is a matter of writing code and >>> managing the compiler's resources. >>> >>> Jerry >>> ______________________________ >>> * Well, alright. It's a tool/skill needed to get DSP done, but itisn't>> DSP.Ok, I will try to do that. Hope it works. Thanks Jordi>>> -- >>> Engineering is the art of making what you want from things you canget.>>> >> >> Ok, but I did the same in both programs and in the test it worksproperly>> and in the other it shows the message :S. Any suggestion? > >It's not a place I've specifically been. Find out where in your >directory heirarchy "DSPF_sp_biquad.asm" is locates and tell the linker >-- browse to it -- when it asks. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >
