Hi all, I am trying to post a software interrupt from an interrupt service routine of a hardware interrupt which comes every 7 micro seconds. I post the SWI only when a particular condition is met in the isr. But after this SWI interrupt gets posted the program hangs...on halting i could see that the program is running on a self loop (a branch instruction to its location) called F_BXN_Selfloop(not mine...its from DSP/BIOS). Actually the SWI_post(I single stepped through it after breaking) function has run and the SWI has become ready(viewed in kernel/Object view). After the SWI has become ready my isr runs one more times and then everything stops and program is in self loop My isr takes 2 microseconds to run...written in assembly...i am working with TMS320C5510. Does any body has any clue Thanks in advance bye Ajith
DSP/BIOS: SWI from ISR
Started by ●March 19, 2004
Reply by ●March 21, 20042004-03-21
Possibly because the ISR is not in the interrupt vector table. Lookup IRQ_plug, for more information. Robert www.gldsp.com ajith_cet@SoftHome.net (Ajith) wrote:>Hi all, > I am trying to post a software interrupt from an interrupt >service routine of a hardware interrupt which comes every 7 micro >seconds. I post the SWI only when a particular condition is met in the >isr. > But after this SWI interrupt gets posted the program hangs...on >halting i could see that the program is running on a self loop (a >branch instruction to its location) called F_BXN_Selfloop(not >mine...its from DSP/BIOS). Actually the SWI_post(I single stepped >through it after breaking) function has run and the SWI has become >ready(viewed in kernel/Object view). After the SWI has become ready my >isr runs one more times and then everything stops and program is in >self loop > My isr takes 2 microseconds to run...written in assembly...i am >working with TMS320C5510. Does any body has any clue >Thanks in advance >bye >Ajith( modify address for return email ) www.numbersusa.com www.americanpatrol.com
