Hai, I am using a 1/2 rate convolution encoder and after encoding I am mapping the bits to qpsk constellation.My received signal is of form y = a*s+n. Where 'a' is due to channel fading 's' is qpsk symbol and 'n' is noise.I estimated 'a' (I know 'a') .I have no idea about soft qpsk demapper. that will take N symbols and outputs 2*N coded soft bits. Thank You M.Rakesh
soft demapping of qpsk
Started by ●April 20, 2009
Reply by ●April 20, 20092009-04-20
>Hai, > I am using a 1/2 rate convolution encoder and after encoding I am >mapping the bits to qpsk constellation.My received signal is of form y = >a*s+n. Where 'a' is due to channel fading 's' is qpsk symbol and 'n' is >noise.I estimated 'a' (I know 'a') .I have no idea about soft qpsk >demapper. >that will take N symbols and outputs 2*N coded soft bits. > >Thank You >M.Rakesh > > > >%%% Read section 2 of this paper. http://www.lnt.ei.tum.de/mitarbeiter/goertz/globecom03.pdf IHTH Chintan
STUPIDENT mrakesh85 wrote:> Hai, > I am using a 1/2 rate convolution encoder and after encoding I am > mapping the bits to qpsk constellation.My received signal is of form y = > a*s+n. Where 'a' is due to channel fading 's' is qpsk symbol and 'n' is > noise.I estimated 'a' (I know 'a') .I have no idea about soft qpsk > demapper. > that will take N symbols and outputs 2*N coded soft bits. > > Thank You > M.Rakesh > > >
On Apr 20, 6:21�am, "mrakesh85" <munagalarak...@yahoo.com> wrote:> Hai, > � � I am using a 1/2 rate convolution �encoder and after encoding I am > mapping the bits to qpsk constellation.My received signal is of form y = > a*s+n. Where 'a' is due to channel fading 's' is qpsk symbol and 'n' is > noise.I estimated 'a' (I know 'a') .I have no idea about soft qpsk > demapper. > that will take N symbols and outputs 2*N coded soft bits. > > Thank You > M.RakeshNothing to add, just wanted to change the subject back.
