Hi, why Does MATLAB FIR1 function use -6 dB cutoff frequency instead of -3 dB ? I am using MATLAB 6.5 version. I am trying to design a LPF with the help of FIR1 function. n = 51; % order of the filter wn = 0.4 % cutoff frequency fir1(n,wn); freqz(b); Now my cutoff frequency should come on the -3 dB level but it is on -6 dB level. Regards Abhishek
Started by ●March 17, 2004
Reply by ●March 17, 20042004-03-17
Abhishek Agrawal wrote:> Hi, > > why Does MATLAB FIR1 function use -6 dB cutoff frequency instead > of -3 dB ? > > I am using MATLAB 6.5 version. > > I am trying to design a LPF with the help of FIR1 function. > > n = 51; % order of the filter > wn = 0.4 % cutoff frequency > fir1(n,wn); > freqz(b); > > Now my cutoff frequency should come on the -3 dB level but it is > on -6 dB level."help fir1" tells at least that this is what you should expect. "fdatool" reveals that this is a property of the algorithm they use for calculation of windowed fir filter coefficients. Maximally-flat fir filters instead provide -3dB at the wn-location. Did you consider posting this question to the comp.soft-sys.matlab ng? Bernhard> > > > Regards > Abhishek
