Hello, Which of the following two definitions is correct for convolution of 2 complex signals? (1): x1(t) convolve x2(t) = int from -inf to +inf [ x1(tau) x2*(t-tau) ] dtau (2): x1(t) convolve x2(t) = int from -inf to +inf [ x1(tau) x2(t-tau) ] dtau Here x2*(.) is the complex conjugate of x2(.). I would appreciate it if you could also point me to a textbook which confirms your answer. Thanks, Carl
Definition of convolution of 2 complex signals
Started by ●April 27, 2009
Reply by ●April 28, 20092009-04-28
On 28 Apr, 03:55, carl.horto...@gmail.com wrote:> Hello, > > Which of the following two definitions is correct for convolution > of 2 complex signals? > > (1): > x1(t) convolve x2(t) = int from -inf to +inf [ x1(tau) x2*(t-tau) ] > dtau > > (2): > x1(t) convolve x2(t) = int from -inf to +inf [ x1(tau) x2(t-tau) ] > dtau > > Here x2*(.) is the complex conjugate of x2(.).If you derive the convolution sum formula frm scratch, see http://groups.google.no/group/comp.dsp/msg/f99bcd270cc776d8?hl=no& with complex-valued x and h, the same form as in the real-valued case pops out. No complex conjugates anywhere.> I would appreciate it if you could also point me to a textbook which > confirms your answer.Can't remember having seen complex-valued convolutions having been discussed in any textbooks. Rune
