Hi i have a free online article : root selection methods in flood analysis http://www.hydrol-earth-syst-sci.net/7/151/2003/hess-7-151-2003.html and there is a z transform for the unit hydrograph for a single reservoir (Nash-cascade) i can't figure out how its made ! in the time domaine single reservoir is y=1/K*exp(- t/K) general form for n- reservoirs y=[ ( 1/( K*(n-1)! ) )* (x/K).^(n-1).* exp(-t/K) ] where N=100 t=1,2,3 ... N K=storage const n=1 single reservoire Y(z^-1)=H(z^-1)X(z^-1) and in the article there two mysterious statments meaby with mistakes ? H(z^-1)=[ ( exp(t/K) -1 )/t ] * exp(-t/K) and below (its multiplicated or its a general form??) { ( 1-[exp(-t/K)z^-1]^N )/ ( 1-exp(-t/K)z^-1 ) } how??? because if you see the analytical form of y it should be a simple transform for the exp set c= 1/K then y=c *exp (- ct) Z{y}=Z{c *exp (- ct)}=c* Z{exp (- ct)} = c/(1-exp (- ct)z^-1) = Y (z^-1) Z{x}=Z{t}= (z^-1)/( (1-z^-1)^2 ) = X(z^-1) and H(z^-1) is simple division of Y(z^-1)/X(z^-1) someone can werify this for me ? ;) with regards Wojtek
z-transform of unit hydrograph help !
Started by ●May 2, 2009
Reply by ●May 2, 20092009-05-02
On Sat, 02 May 2009 01:18:08 -0700, wooopik wrote:> Hi > > i have a free online article : root selection methods in flood analysis > http://www.hydrol-earth-syst-sci.net/7/151/2003/hess-7-151-2003.html and > there is a z transform for the unit hydrograph for a single reservoir > (Nash-cascade) i can't figure out how its made ! > > in the time domaine single reservoir is y=1/K*exp(- t/K) > general form for n- reservoirs > y=[ ( 1/( K*(n-1)! ) )* (x/K).^(n-1).* exp(-t/K) ] > > where N=100 > t=1,2,3 ... N > K=storage const > n=1 single reservoire > > Y(z^-1)=H(z^-1)X(z^-1) > > and in the article there two mysterious statments meaby with mistakes ? > > H(z^-1)=[ ( exp(t/K) -1 )/t ] * exp(-t/K) and below (its multiplicated > or its a general form??) { ( 1-[exp(-t/K)z^-1]^N )/ ( 1-exp(-t/K)z^-1 ) > } > > how??? > because if you see the analytical form of y it should be a simple > transform for the exp set c= 1/K > then > y=c *exp (- ct) > Z{y}=Z{c *exp (- ct)}=c* Z{exp (- ct)} = c/(1-exp (- ct)z^-1) = Y (z^-1) > Z{x}=Z{t}= (z^-1)/( (1-z^-1)^2 ) = X(z^-1) > > and H(z^-1) is simple division of Y(z^-1)/X(z^-1) > > someone can werify this for me ? ;) > > with regards > WojtekI tried, but there's too many distractions in the article. Post equation numbers and maybe I'll try again. Keep in mind that they may be using non-traditional forms. -- http://www.wescottdesign.com
they use z^-1 not z its eq (7) as i say before single reservoire Nash - cascade is y(t)=1/K*exp(- t/K) and x(t)=t for discrete time values t=T*n T=1 n=1 .. N and there is one little mistake in eq (7) in { } should be 1 + exp... in numerator because i have obtain the same results as in Table 1 with + so it seem to be workig i should try the inverse z transform but its a little to hard , i dont have any program for symbolic operations :]
they use z^-1 not z its about eq (7) for single reservoir in time domain whe have y(t)=1/K*exp(- t/K) and x(t)=t i have no ide how they arrived until eq (7) but it seem to be working because i have coherent results i should try a inverse z transform but it a little to hard , i dont have any program for symbolic operations
On Sat, 02 May 2009 11:36:55 -0700, wooopik wrote:> they use z^-1 not z > > its about eq (7) > > for single reservoir in time domain whe have y(t)=1/K*exp(- t/K) and > x(t)=t > i have no ide how they arrived until eq (7) but it seem to be working > because i > have coherent results > > i should try a inverse z transform but it a little to hard , i dont have > any program for symbolic operationsI don't see where they define the single reservoir response -- I think that the time-domain model that you are using is simpler than what they're using -- they seem to imply that the reservoir response has a significant delay component which (a) kinda matches a reservoir that's physically large compared to it's outlet size, and (b) matches my memory of how the water rises in most storms (i.e. it isn't at it's maximum immediately after a whopping big shower; instead it peaks a bit later). -- http://www.wescottdesign.com
