I am using 5X5 and 3X3 kernels to convolve with Image. As I know convolution is computational Intensive and I have to convolve many kernels with my image to achieve the result, the execution takes 2 seconds. I would like to reduce the processing time. When I sequentially convolve kernel with image, the values difference between two sequentially convolution is very less in many places, because the pattern is not changing much. I would like to know using this idea, can I able to reduce the computational time.
Fast Convolution on Images
Started by ●May 9, 2009
Reply by ●May 9, 20092009-05-09
saravanan <saravananrmca@gmail.com> writes:> I am using 5X5 and 3X3 kernels to convolve with Image. As I know > convolution is computational Intensive and I have to convolve many > kernels with my image to achieve the result, the execution takes 2 > seconds. I would like to reduce the processing time. > > When I sequentially convolve kernel with image, the values difference > between two sequentially convolution is very less in many places, > because the pattern is not changing much. I would like to know using > this idea, can I able to reduce the computational time.Hi saravanan, If I understand you correctly, you can't. At least you can't without introducing some type of error. There are at least two other possibilities, however: 1. Use frequency-domain filtering. 2. Find out if your psf is separable. I really like Steve Eddins' article about this over at the Mathworks blogs: http://blogs.mathworks.com/steve/2006/10/04/separable-convolution/ -- % Randy Yates % "She tells me that she likes me very much, %% Fuquay-Varina, NC % but when I try to touch, she makes it %%% 919-577-9882 % all too clear." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://www.digitalsignallabs.com
