Hi, Suppose I have to extract a single 200kHz channel from the GSM band and I'd do it using a non-linear phase response filter. Could someone give me an idea or a reference on how to evaluate the impact of the phase distortion? I mean how the GMSK demodulation process will be affected. Any advice or reference regarding this would be appreciated. thank you, friedman
GSM channel filter
Started by ●May 27, 2009
Reply by ●May 27, 20092009-05-27
friedman wrote:> Hi, > > Suppose I have to extract a single 200kHz channel from the GSM band and > I'd do it using a non-linear phase response filter. Could someone give me > an idea or a reference on how to evaluate the impact of the phase > distortion?Take the difference between the original and the altered spectrums. Think of this difference as if it is a noise which is added to the original signal. Compute the equivalent SNR impairment due to that noise.> I mean how the GMSK demodulation process will be affected. Any > advice or reference regarding this would be appreciated.If you have the amplitude limiter after the filter (which is the usual case), this becomes the tough nonlinear problem. If you don't, then the filter can be accounted for. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●May 29, 20092009-05-29
Thank you for the answer Vladimir,> >friedman wrote: >> Hi, >> >> Suppose I have to extract a single 200kHz channel from the GSM bandand>> I'd do it using a non-linear phase response filter. Could someone giveme>> an idea or a reference on how to evaluate the impact of the phase >> distortion? > >Take the difference between the original and the altered spectrums. >Think of this difference as if it is a noise which is added to the >original signal. Compute the equivalent SNR impairment due to thatnoise.>This would mean to be able to implement a sufficient long FIR filter for generating my reference, which could be a problem. I was wondering if anyone was aware of some analytical results or, better, methods to investigate this.>> I mean how the GMSK demodulation process will be affected. Any >> advice or reference regarding this would be appreciated. > >If you have the amplitude limiter after the filter (which is the usual >case), this becomes the tough nonlinear problem. If you don't, then the >filter can be accounted for. >Are you aware of any other "UNusual" case regarding the receiver structure in a typical SDR platform? Do you know any "didactic" (maybe even open?) SDR implementation (with software channel separation) suited for analyzing GSM signal? Thanks, Friedman
friedman wrote:> Thank you for the answer Vladimir, > > >>friedman wrote: >> >>>Hi, >>> >>>Suppose I have to extract a single 200kHz channel from the GSM band > > and > >>>I'd do it using a non-linear phase response filter. Could someone give > > me > >>>an idea or a reference on how to evaluate the impact of the phase >>>distortion? >> >>Take the difference between the original and the altered spectrums. >>Think of this difference as if it is a noise which is added to the >>original signal. Compute the equivalent SNR impairment due to that > > noise. > > > > This would mean to be able to implement a sufficient long FIR filter for > generating my reference, which could be a problem.If this is a problem for you, stop here.> I was wondering if > anyone was aware of some analytical results or, better, methods to > investigate this.Investigate exactly what? The dependence of what from which in the case of what? There were tons of books and publications about GSM in 80x.>>>I mean how the GMSK demodulation process will be affected. Any >>>advice or reference regarding this would be appreciated. >> >>If you have the amplitude limiter after the filter (which is the usual >>case), this becomes the tough nonlinear problem. If you don't, then the >>filter can be accounted for. >> > Are you aware of any other "UNusual" case regarding the receiver structure > in a typical SDR platform?A trivial discriminator followed by DFE is usual. Of course, there could be better approaches depending on what is available, however the first> Do you know any "didactic" (maybe even open?) > SDR implementation (with software channel separation)^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Bad idea. Drowning in the intermodulation products.> suited for analyzing > GSM signal?DYI. It is quite simple. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
