Hi, I am trying to design proper anti-aliasing filters for a new hobby project (digital control of a quad-rotor flying robot - see previous post for more questions). Here are the specifics: * My sensors are analog MEMS accelerometers and gyroscopes. I'll have at least 6 sensors to process, at least initially. * I will be using a microcontroller with 10-12 bit built-in ADCs to process the sensor data (and implement the control loops) * I'd like to keep part counts and costs to a minimum (of course) * I'd like to employ oversampling so I can make use of an analog anti- alias filter with a (relatively) low number of poles * I'll need to implement a digital filter + decimation to get down to the desired sample rate * I'd like to average the samples (prior to the digital filter? although the averager is itself a digital filter) to improve the effective number of bits of resolution. So, here are my questions: * Can anyone recommend a good references for such a design, combining these elements? * How important is it to use a Bessel filter (linear phase) vs butterworth (flat passband response) in the analog filter stage? * What kinds of filter-on-a-chip IC packages exist out there? I think I'd prefer a switched capacitor or other easily varied type of configuration (so I can make certain filter changes without altering hardware) * Are there any microcontrollers that automate the sampling and digital filtering processing, with minimal direct intervention? It looks as if the Luminary Micro ARM line has some hardware sample averaging capability, for example, but it is not clear if it can handle 6 simultaneous analog channels. Thanks in advance Roy
Design of anti-alias filter for ADC, with oversampling and averaging
Started by ●June 9, 2009
Reply by ●June 9, 20092009-06-09
On Mon, 08 Jun 2009 21:26:36 -0700, Roy wrote:> Hi, > > I am trying to design proper anti-aliasing filters for a new hobby > project (digital control of a quad-rotor flying robot - see previous > post for more questions). Here are the specifics: > > * My sensors are analog MEMS accelerometers and gyroscopes. I'll have > at least 6 sensors to process, at least initially. * I will be using a > microcontroller with 10-12 bit built-in ADCs to process the sensor data > (and implement the control loops) * I'd like to keep part counts and > costs to a minimum (of course) * I'd like to employ oversampling so I > can make use of an analog anti- alias filter with a (relatively) low > number of poles * I'll need to implement a digital filter + decimation > to get down to the desired sample rate > * I'd like to average the samples (prior to the digital filter? although > the averager is itself a digital filter) to improve the effective number > of bits of resolution. > > So, here are my questions: > * Can anyone recommend a good references for such a design, combining > these elements? > * How important is it to use a Bessel filter (linear phase) vs > butterworth (flat passband response) in the analog filter stage? * What > kinds of filter-on-a-chip IC packages exist out there? I think I'd > prefer a switched capacitor or other easily varied type of configuration > (so I can make certain filter changes without altering hardware) > * Are there any microcontrollers that automate the sampling and digital > filtering processing, with minimal direct intervention? It looks as if > the Luminary Micro ARM line has some hardware sample averaging > capability, for example, but it is not clear if it can handle 6 > simultaneous analog channels. >Here is a block diagram of my recommended anti-alias filter for 95% of all digital control loops out there: _____ | | ---->| 1 |-----> |_____| IOW, don't do it. The only time you need an anti-aliasing filter is if you have lots of noise at close to your sampling rate. Otherwise, the most significant contribution that an anti-alias filter can have in a closed loop is excessive phase delay. Having said that, usually when I have the chance I'll oversample the ADC, and hand the controller the sum of the ADC samples in the interval leading up to the controller sample interval. I.e., if I'm sampling the controller at 500Hz, I may sample the ADC at 8000Hz and deliver the sum of the last 16 ADC samples to the controller. This knocks down the ADC noise nicely, and makes a comb filter for any external signal that wants to interfere with my loop. It does add delay, but the delay is minimal for those frequencies that would alias down into my loop. -- www.wescottdesign.com
