Hi Guys, I am hoping someone in this group would be able to answer this question. I am working on a Reed-Solomon decoder for WiMAX 802.16-2004. Its a RS(255,239,T=8) code. The generator polynomial is g(x) = (x + a^0)(x + a^1)(x + a^2) ...(x + a^(2T-1)) You'll notice that the first root of g(x) is 1. I have run into a problem when I use this g(x). It seems the error evaluator polynomial is not being calculated corectly by my modified euclidean algorithm but the error locator polynomial being calculated is correct. If I use a generator polynomial which has a^1 as its first root i.e g (x) = (x + a^1)(x + a^2) ...(x + a^2T) then both polynomials are being correctly calculated by the Euclids algorithm. I haven't been able to find any info on what needs to be tweaked if the first root is not a^1. I hope some has a solution for this. Thanks Sudhir
A Reed-Solomon Decoder Question
Started by ●June 16, 2009
Reply by ●June 16, 20092009-06-16
On Jun 16, 5:58�pm, Sudhir Singh <Sudhir.Si...@email.com> wrote:> I haven't been able to find any info on what needs to be > tweaked if the first root is not a^1.Assuming that you have programmed the Euclidean algorithm correctly, your program will give you the error-evaluator polynomial, but the answer that you will get when the first root is a^1 is not the same as the answer you will get when the first root is a^0 = 1. Note: the Euclidean algorithm does not know (and does not need to know) whether the first root of g(x) is a^0 or a^1 or whatever: it returns the correct error-evaluator polynomial, but how you use it thereafter can cause you much grief. The definition of the error-evaluator polynomial depends on what the first root is, and correspondingly, the Forney error value formula also depends on what the first root is. So if your first root is a^0, use the corresponding Forney formula and you will get the error values that you know that you are supposed to get. But if instead you use the Forney formula for the case of first root being a^1 with the error evaluator polynomial for the case of first root being a^0, you will not get the error values, and you may suspect that something is wrong with the Euclidean algorithm. See the paper at (http://www.ifp.illinois.edu/~sarwate/pubs/Sarwate01High.pdf) for the definitions of the various polynomials, the Forney formula, etc. for the case when the first root is not a^1. The paper itself deals with Berlekamp-Massey decoders, but the basic stuff is all the same. Hope this helps. --Dilip Sarwate
Reply by ●June 17, 20092009-06-17
