Given a electromagnetic source with a certain carrier frequency, how fast can it be modulated (modulation type aside)? Usually, it is said that the obtainable bandwidth, by rule of thumb, is around 10% of the carrier frequency...Does anyone know why? the physical reason? In ON-OFF keying, can a pulse be shorter in time than a cycle of the carrier? thanks fisico32
carrier freq. and pulse length
Started by ●June 17, 2009
Reply by ●June 17, 20092009-06-17
fisico32 wrote:> Given a electromagnetic source with a certain carrier frequency, how fast > can it be modulated (modulation type aside)?How fast delta function could be?> Usually, it is said that the > obtainable bandwidth, by rule of thumb, is around 10% of the carrier > frequency...Does anyone know why? the physical reason?Technical difficulties with RF amplifiers and antennae.> In ON-OFF keying, can a pulse be shorter in time than a cycle of the > carrier?Yes, but what is the point?> thanks > fisico32VLV
Reply by ●June 18, 20092009-06-18
>The reason I ask is because I was wondering if there is any limitation dueto a minimum number of wave cycles that need to be in a 1 bit..... If not, as you say, then there is no difference in how short we can make a 1 bit pulse using a carrier with higher frequency than another one....> >fisico32 wrote: > >> Given a electromagnetic source with a certain carrier frequency, howfast>> can it be modulated (modulation type aside)? > >How fast delta function could be? > >> Usually, it is said that the >> obtainable bandwidth, by rule of thumb, is around 10% of the carrier >> frequency...Does anyone know why? the physical reason? > >Technical difficulties with RF amplifiers and antennae. > >> In ON-OFF keying, can a pulse be shorter in time than a cycle of the >> carrier? > >Yes, but what is the point? > >> thanks >> fisico32 > >VLV >
