Hi Has anybody worked on a DSP algorithm running partly on ARM core and partly on DSP core on a OMAP or any similar Chip. The algorithm i mean only the DSP algorithm (some video or image codec). I wonder if anybody has engineered such an impementation. just curious to know.
DSP algorithm (may be some video or image codec or anything) running partly on the ARM core and partly on DSP core of a an OMAP or a similar multicore chip.
Started by ●June 23, 2009
Reply by ●June 23, 20092009-06-23
rajesh wrote:> Has anybody worked on a DSP algorithm running partly on ARM core and > partly on DSP core on a OMAP or any similar Chip.I've done the designs like that many times. Small DSP for the brute force number crunching in the real time, and a general purpose CPU for the intelligent part.> The algorithm i mean only the DSP > algorithm (some video or image codec). > > I wonder if anybody has engineered such an impementation. just curious > to know.Having everything in one CPU (or DSP) is much simpler; however the cost of one do-it-all big processor could be higher then the two smaller ones. That's the only point. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●June 24, 20092009-06-24
On Jun 23, 7:50 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> rajesh wrote: > > Has anybody worked on a DSP algorithm running partly on ARM core and > > partly on DSP core on a OMAP or any similar Chip. > > I've done the designs like that many times. Small DSP for the brute > force number crunching in the real time, and a general purpose CPU for > the intelligent part. > > > The algorithm i mean only the DSP > > algorithm (some video or image codec). > > > I wonder if anybody has engineered such an impementation. just curious > > to know. > > Having everything in one CPU (or DSP) is much simpler; however the cost > of one do-it-all big processor could be higher then the two smaller > ones. That's the only point. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comDont you think that the algorithm should be flexible enough for that, with minimum dependencies ? Any way you must be kiddin !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!(not one but you)
