hi all, assuming a 4 or 8-antenna (multi-carrier based) communication system with DOA estimation (by music or espirit or any 4 or 8 antenna phase estimation algorithm). two situations as given below. 1. LOS or NLOS: - how can i identify Line of Sight or Non Line of Sight type of channel through beamweights. (assuming i dont have any access to channel estimates) 2. even in LOS ..when a modem is transmitting in Uplink..its transmisison can get scattered (ofcourse a strong LOS path exists..) and can form multipaths and also in case of NLOS..modem's transmitted signal can scatter through multipaths before reaching base station. So essentially multipaths are present on both LOS and NLOS environments...in this case.with beam weight estimation..how can i differentiate between LOS and NLOS environments.. i mean to ask..how does beam vary in LOS or NLOS ..and in multipath environments.. thanks particle filter reddy
identification of LOS or NLOS through ?????
Started by ●July 7, 2009
