For starters apologies in advance if I'm in in the wrong NG. Downloaded fftw and I'm trying to get an assessment on the output surround the command 'bench -sib246'. On my machine this outputs: C:\dev\vc++_2008\fft\fftw>lib /def:libfftw3-3.def 'lib' is not recognized as an internal or external command, operable program or batch file. C:\dev\vc++_2008\fft\fftw>bench -s option -s requires an argument C:\dev\vc++_2008\fft\fftw>bench -sib256 Problem: ib256, setup: 46.36 ms, time: 2.64 us, ``mflops'': 3881 Three questions: a) I'm not following what the 46.36ms of 'setup' entails and the di b) How is time measured here. Is this as simple as: //start the clock start = std::clock(); // stop the clock elapsed = (diff_type)std::clock() - start; elapsed /= CLOCKS_PER_SEC; c) bench executed "in-place backward complex transform of size 256". This in my view means an array length 256 of complex type. I suspect the content is irrelevant? Just trying to get a feel for the 'what the complex type entails'
fftw bench assessment
Started by ●July 31, 2009
