Import and Export to a makefile
Started by Peter Xu March 10, 2004
In Code Composer Studio (CCS) of Texas Instruments one can import a makefile
or export a project file to a makefile. How useful is this feature? Thank
you.
If you want to use another IDE/editor such as CodeWright or UltraEdit,
you'll want to export your makefile or create one from scratch.  I
worked on a project using another OS that required a post-link utility.
  I am not sure if you can add post-link/DOS executions to a CCS
project, but if the answer is yes, I could have stuck with the CCS IDE.
  Still, CodeWright is a better editor and I was still able to use CCS
for debugging.
regards,
Dan Ash
makefile
 > you.
