Shimon M wrote: ..> I read your "FFT in a day" and also tried the above links - but I was > still baffled. I tried Audacity's program on a wave file produced like > this: > a recurring C4 (261.626 Hz), and then tried Analyze > Plot spectrum > and got: > 255.706787 -54.295128 > 258.398438 -48.651611 > 261.090088 -40.968891 (no apparent importance) > 263.781738 -39.088898 > 266.473389 -44.641678 > 269.165039 -54.939251 > > > but then - I tried changing the axis to "log frequency" and got: > apperant peaks at 130 and 261 - so I am stasified. > > So, I conclude the problem is this "log axis"You appear to be struggling with the numbers. In the above listing, the second columm is in dB (relative to maximum = 0dBFS), and ~very obviously~ the 261Hz and 263 points form a narrow (i.e. prominent) peak. The bin marked -39dB is the loudest of those shown. They are very clearly ~not~ of "no apparent importance". The log axis merely shows up this detail more clearly by magnifying the spacing at low frequencies. It does not magically conjure up new information, it simply spreads out the existing information in a particular way. Which is to say, it is mostly a convenience for display purposes - the underlying FFT data is still linearly spaced. It does not in any way relieve you of the need to be comfortable with the linear frequency spacing of the FFT. Your reference to 'this "log axis" ' rather implies you have not come across such a thing before. You need to spend some time hanging out with electronic engineers - folk who use oscilloscopes, function generators and spectrum analysers. You may even find people in music recording studios using them. It will then quickly become apparent that the log scale is what they use, 99% of the time. Any time a musician talks about an octave, they are using a log scale. Richard Dobson
Sound analysis
Started by ●September 2, 2009
Reply by ●September 3, 20092009-09-03
Reply by ●September 4, 20092009-09-04
One last question, if I may: How may I reverse a fourier transfrom? I assume that is a bit hard - since I only got a finite number of frequencies from the fourier transfrom. So, if I wanted to reverse it - I'll need to integrate on all possible frequncies (which I don't have). Nevertheless, Since I can only re-build a finite, discrete signal - there is pobably an approximation good enough, using a sum (as opposed to integral). Thank you.
On 4 Sep, 12:08, "Shimon M" <shimon.ma...@gmail.com> wrote:> One last question, if I may: > > How may I reverse a fourier transfrom? > > I assume that is a bit hard - since I only got a finite number of > frequencies from the fourier transfrom.The Discrete Fourier Transform (DFT) is exact for the data you actually have - discrete-time data of finite extent.> So, if I wanted to reverse it - > I'll need to integrate on all possible frequncies (which I don't have)....which is why a DFT can only be an approximation of what most people mean by 'Fourier Transform' (FT of continuous data of infinite extent)...> Nevertheless, Since I can only re-build a finite, discrete signal - there > is pobably an approximation good enough, using a sum (as opposed to > integral).Use the Inverse DFT, IDFT. The DFT/IDFT pair is exact for discrete data of finite extent. Rune
Reply by ●September 5, 20092009-09-05
On Sep 2, 4:46=A0am, "Shimon M" <shimon.ma...@gmail.com> wrote:> Hello, Everyone, > > I am designing a software for a course, and it is suppose to do the > following: > 1. get a wave file > 2. analyze it - to notes and instruments that play them > 3. enable changing an instrument with another. > > Yes, I know these are all things that are under research, and that there > is no magic solution. > > Yet, since this is for a course, it doesn't have to be robust - if I can > get it to work only on a small group of samples, that would be OK. So I > chose GuitarProDon't use guitar sounds. The frequencies produced by stringed instruments are not the same as the musical pitch, especially for low notes (much lower than Concert A). To make things simple for a student project, try flute music in the mid to high range for a much simpler spectra. Play songs with a very slow tempo, say 60 bpm. If you plan on using an FFT, see the list on my web page of a few misunderstandings on how an FFT works. http://www.nicholson.com/rhn/dsp.html IMHO. Good Luck. -- rhn A.T nicholson d.0.t C-o-M
Reply by ●September 7, 20092009-09-07
Hello again - Thank you for all your help, I have made greaqt progress with it, and I am close to finishing my project. I have two final question: 1. Volume issue: It is my understanding that sample points on which we preform FT (or FFT), are basically the energy sampled at that point. However, when I create samples for testing - I notice that: On a smaple of C note at volume 16 (guitar pro units) - the FFT returns a certain amplitude for 261.626 Hz. but, on a similar sample with volume 8 - this amplitude is a bit larger! Is this because the results I am seeing are basically relative, and not absolute (I expected all amplitudes to drop by half - or by some factor [in case the units are linear to decibels], but instead amplitude for C increased! [only a bit]). Any explanation? This is my last obsticle in completing the prj. Thank you.
Shimon M wrote:> Hello again - Thank you for all your help, I have made greaqt progress > with it, and I am close to finishing my project. > > I have two final question: > 1. Volume issue: > It is my understanding that sample points on which we preform FT (or FFT), > are basically the energy sampled at that point. However, when I create > samples for testing - I notice that: > > On a smaple of C note at volume 16 (guitar pro units) - the FFT returns a > certain amplitude for 261.626 Hz. > > but, on a similar sample with volume 8 - this amplitude is a bit larger! >Too vague - "a bit larger" tells us nothing useful. We need (and you should be supplying) hard numbers.> Is this because the results I am seeing are basically relative, and not > absolute (I expected all amplitudes to drop by half - or by some factor [in > case the units are linear to decibels], but instead amplitude for C > increased! [only a bit]). > > Any explanation? This is my last obsticle in completing the prj.Impossible to say fur sure without knowing what Guitar Pro is meant to be doing with those units. However, if the application selects or synthesizes (or low pass filters) a tone dependent on the requested volume, one would expect the quieter note to have less HF energy than the louder one; so that the ~relative~ amount of fundamental will be greater in the quieter tone. Listening to the sounds should settle the question. You may need to revise your expectations in this respect. And of course, make sure the sound is not going through any non-linear processing such as compressors, etc. Much software ("pro" and otherwise) relies heavily on such things to give their otherwise meagre sounds some apparent substance and "power". Richard Dobson.
On 7 Sep, 13:07, Richard Dobson <richarddob...@blueyonder.co.uk> wrote:> > Any explanation? This is my last obsticle in completing the prj. > > Impossible to say fur sure without knowing what Guitar Pro is meant to > be doing with those units....keep in mind that it *could* be as simple as scaling the samples by some constant gain factor... Rune
Rune Allnor wrote:> On 7 Sep, 13:07, Richard Dobson <richarddob...@blueyonder.co.uk> > wrote: > >>> Any explanation? This is my last obsticle in completing the prj. >> Impossible to say fur sure without knowing what Guitar Pro is meant to >> be doing with those units. > > ...keep in mind that it *could* be as simple as scaling > the samples by some constant gain factor... >Indeed. The raw samples are very likely normalized and/or in some way relatively equalized; the OP is ostensibly recording the performance output. We do not know if the same sample is used. If the instrument is comprehensively multi-sampled, different samples are recorded not only with respect to pitch, but also with respect to dynamics. I.e. one sample is used for forte and a different one is used for piano. GP is advertised as offering highly realistic performance (however one is suppose to judge that), which would make multi-sampling pretty well mandatory. So it is a reasonable prediction that the quieter note is not simply the louder note attenuated; depending on how different the two specified GP levels are. It may very well be that the assumptions the OP is making abut how the software works are unwarranted, and risk leading to false or confused results. Richard Dobson
I came back with numbers: On C(4) with volume 16: the fequency 261.626 gets 86,515 On 15: 98,206 On 10: 40,688 On 5: 277,891 On 2: 100,165 So I am baffled all completley. When I listen to it, it does sound lower! and more importantly, I printed out the array of the sample each time, and the numbers look lower (closer to zero, everytime I lower the volume), but the FT's result doesn't go down, necessarilly. Another question - I used Audacity on samples and got on volumes 16,8,4,2 - dB -33, -38, -45, -57. Why are dB negative in audacity? What is the ralatioship between these numbers? I am assuming it is logarithmic. Thank you, again.
Shimon M wrote:> I came back with numbers: > > On C(4) with volume 16: the fequency 261.626 gets 86,515 > On 15: 98,206 > On 10: 40,688 > On 5: 277,891 > On 2: 100,165 > > So I am baffled all completley. > > When I listen to it, it does sound lower! and more importantly, I printed > out the array of the sample each time, and the numbers look lower (closer > to zero, everytime I lower the volume), but the FT's result doesn't go > down, necessarilly. >Are you certain your FFT is correct? You need someone in your department qualified to do so, to look at it. Have you tested it with a plain sinusoidal input?> Another question - I used Audacity on samples and got on volumes 16,8,4,2 > - dB -33, -38, -45, -57. >That's reasonably reasonable. Suggests there is indeed something wrong either with your FFT, or with how you are reading your sample data.> Why are dB negative in audacity? > What is the ralationship between these numbers? I am assuming it is > logarithmic.These are ~very~ basic, almost elementary questions! See here: http://en.wikipedia.org/wiki/DBFS Here's a clue: say that digital peak = 1.0, digital silence = 0. Take the log of each (try it on your calculator). Which is the more useful as a reference level? You ~absolutely~ need to be fully conversant with all the numbers and units you are working with; whether the dB scale as used everywhere in the music industry, or the output of a correctly implemented FFT. That is not something that can possibly be addressed here. There must be someone in your department who knows the basics of digital audio and could help you. If not, who will assess your project? Richard Dobson
