Can anyone help me do scaling for matlab's mscohere? I have two time series x and Y of the same length (1x220) which I want to know the relationships spectrally. mscohere gives me the coherence (cxy) with a vector (1 x 146) which is lower than the length of x or y. I can't explain it, so is there anyway I can make a better plot where I can derive any meaning? The peaks are ok ranging from 0-1. The xaxis is not. Regards Brett
Help Coherence in matlab
Started by ●September 17, 2009
Reply by ●September 17, 20092009-09-17
bluenoble4u wrote:> Can anyone help me do scaling for matlab's mscohere? > > I have two time series x and Y of the same length (1x220) which I want to > know the relationships spectrally. mscohere gives me the coherence (cxy) > with a vector (1 x 146) which is lower than the length of x or y. I can't > explain it, so is there anyway I can make a better plot where I can derive > any meaning? The peaks are ok ranging from 0-1. The xaxis is not. > > Regards > Brett > >
Reply by ●September 19, 20092009-09-19
On Thu, 17 Sep 2009 09:08:06 -0500, "bluenoble4u" <bluenoble4u@yahoo.com> wrote:>Can anyone help me do scaling for matlab's mscohere? > >I have two time series x and Y of the same length (1x220) which I want to >know the relationships spectrally. mscohere gives me the coherence (cxy) >with a vector (1 x 146) which is lower than the length of x or y. I can't >explain it, so is there anyway I can make a better plot where I can derive >any meaning? The peaks are ok ranging from 0-1. The xaxis is not. > >Regards >BrettHi, My old version of MATLAB doesn't have that built-in mscohere() function. So I can't help ya' out here. I did take a quick look at: http://www.mathworks.com/access/helpdesk/help/toolbox/signal/index.html?/access/helpdesk/help/toolbox/signal/mscohere.html&http://www.google.com/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.mathworks.com%2Faccess%2Fhelpdesk%2Fhelp%2Ftoolbox%2Fsignal%2Fmscohere.html&ei=NMq0SvzfJ4j6sQP17NnRDA&rct=j&q=matlab+mscohere&usg=AFQjCNFaq_IEXffDyb3OMAdIPL3uzuz1Kg It looks like the mscohere() function is fairly complicated and it uses Welch's Method of partitioning (breaking) input sequences into smaller blocks of samples on which to perform spectrum analysis. Also, the web site said something about mscohere() "returning a one-sided coherence estimate." I interpret that, knowing no better, that the function's output only covers the positive freq range. I'd better quit here, because I really don't know enough about mscohere() to fill a thimble. Good Luck, [-Rick-]
