On 9/20/2009 6:37 PM, Bret Cahill wrote:>>>>> If the noise includes some DC it seems that a matched filter would >>>>> treat it as a zero frequency "curve" and eliminate it in the >>>>> convolution along with all the higher frequency noise. >>>> What noise? >>> The noise that got into the original signal has some AC and a DC >>> offset. >>> Matched filtering should eliminate the DC as well as the AC. >>> Bret Cahill>> How can a matched filter eliminate in-band noise? DC or AC? > > That's someone else's issue.The point is the assumption is flawed.> The immediate issue here is if can you assume DC to be a zero > frequency AC as far as matched filtering is concerned.You can always assume it. It may completely screw up your system depending on its sensitivity to DC, though.> If convolution in the time domain amounts to multiplication in the > frequency domain then, at first glance, DC or square wave noise should > be filtered along with the AC noise..Convolution in TD is, in fact, multiplication in FD. That doesn't change the issue of eliminating noise or interference in the passband of a filter. It sounds to me like you are ascribing properties to matched filters that they don't have, e.g., eliminating noise or DC from the passband. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Matched Filtering DC Noise Out
Started by ●September 18, 2009
Reply by ●September 21, 20092009-09-21
> >>>>> If the noise includes some DC it seems that a matched filter would > >>>>> treat it as a zero frequency "curve" and eliminate it in the > >>>>> convolution along with all the higher frequency noise. > >>>> What noise? > >>> The noise that got into the original signal has some AC and a DC > >>> offset. > >>> Matched filtering should eliminate the DC as well as the AC. > >>> Bret Cahill > >> How can a matched filter eliminate in-band noise? � DC or AC? > > > That's someone else's issue. > > The point is the assumption is flawed. > > > The immediate issue here is if can you assume DC to be a zero > > frequency AC as far as matched filtering is concerned. > > You can always assume it. �It may completely screw up your system > depending on its sensitivity to DC, though. > > > If convolution in the time domain amounts to multiplication in the > > frequency domain then, at first glance, DC or square wave noise should > > be filtered along with the AC noise.. > > Convolution in TD is, in fact, multiplication in FD. � That doesn't > change the issue of eliminating noise or interference in the passband of > a filter. > > It sounds to me like you are ascribing properties to matched filters > that they don't have, e.g., eliminating noise or DC from the passband.A simple analog R-to-ground C filter can eliminate DC so maybe that's not so much an issue. A bigger problem would be optimum pulse shaping when the 1st derivative of the signal needs to be, for other reasons, at a minimum as much as possible. This consideration may outweigh the noise problems and I may be stuck with a simple sine wave. Is a simple sine wave any good in a matched filter or does the pulse shape need more "personality" something for FFT to munch on? Bret Cahill
Reply by ●September 22, 20092009-09-22
> > >>>>> If the noise includes some DC it seems that a matched filter would > > >>>>> treat it as a zero frequency "curve" and eliminate it in the > > >>>>> convolution along with all the higher frequency noise. > > >>>> What noise? > > >>> The noise that got into the original signal has some AC and a DC > > >>> offset. > > >>> Matched filtering should eliminate the DC as well as the AC. > > >>> Bret Cahill > > >> How can a matched filter eliminate in-band noise? � DC or AC? > > > > That's someone else's issue. > > > The point is the assumption is flawed. > > > > The immediate issue here is if can you assume DC to be a zero > > > frequency AC as far as matched filtering is concerned. > > > You can always assume it. �It may completely screw up your system > > depending on its sensitivity to DC, though. > > > > If convolution in the time domain amounts to multiplication in the > > > frequency domain then, at first glance, DC or square wave noise should > > > be filtered along with the AC noise.. > > > Convolution in TD is, in fact, multiplication in FD. � That doesn't > > change the issue of eliminating noise or interference in the passband of > > a filter. > > > It sounds to me like you are ascribing properties to matched filters > > that they don't have, e.g., eliminating noise or DC from the passband. > > A simple analog R-to-ground C filter can eliminate DC so maybe that's > not so much an issue. > > A bigger problem would be optimum pulse shaping when the 1st > derivative of the signal needs to be, for other reasons, at a minimum > as much as possible. �This consideration may outweigh the noise > problems and I may be stuck with a simple sine wave. > > Is a simple sine wave any good in a matched filter or does the pulse > shape need more "personality" something for FFT to munch on?Mozart didn't like the flute for the same reason -- nothing but a sterile sine wave. Bret Cahill
