I have a problem I'm hoping someone can help me with. I have an ADSP-20165L system with external SRAM and have moved the $C_CPP_LIBS to SRAM as shown in the snip from my ldf below: ... $DEF_LIBS = libdsp.dlb; $C_CPP_LIBS = libc.dlb, libcpp.dlb, libcpprt.dlb, libio.dlb; $LIBRARIES = $DEF_LIBS, $C_CPP_LIBS; ... seg_pm_sdram { TYPE(PM RAM) START(0x00020000) END(0x00027fff) WIDTH(32) } seg_dm_sdram { TYPE(DM RAM) START(0x00030000) END(0x0005ffff) WIDTH(32) } SECTIONS { ... // .text output section seg_pm_sdram { // INPUT_SECTIONS( $C_CPP_LIBS(seg_pmco) ... ) INPUT_SECTIONS( $C_CPP_LIBS(seg_pmco) ... ) } > seg_pm_sdram Ignore the sdram labels and substitute sram as this system has no sdram. When I load this program in the IDE using the F7 Build Project key, my SYSCON and WAIT registers get trashed. I have traced the problem to a section of the library initialization in "__lib_setup_heaps" in the section with the heading "loop_thru_heaps". After fairly large number of iterations, SYSCON and WAIT get overwritten, usually with 0x00000000. Any ideas?
ADSP-21065L SYSCON overwrite
Started by ●March 4, 2004
Reply by ●March 5, 20042004-03-05
sholle@link-comm.com (Steve Holle) wrote in news:ba83847d.0403041413.57c4860a@posting.google.com:> When I load this program in the IDE using the F7 Build Project key, my > SYSCON and WAIT registers get trashed. I have traced the problem to a > section of the library initialization in "__lib_setup_heaps" in the > section with the heading "loop_thru_heaps". After fairly large number > of iterations, SYSCON and WAIT get overwritten, usually with > 0x00000000.Did you define any heaps? You need a small amount of space in that section to satisfy one iteration of the initializer loop. It's been a long time since I looked at it so I don't recall in detail how much you need, but I think it was 4-6 words of zero.
Kenneth Porter <ken.blacklist@sewingwitch.com> wrote in message news:<Xns94A2D3022ED88shivawellcom@64.164.98.49>...> sholle@link-comm.com (Steve Holle) wrote in > news:ba83847d.0403041413.57c4860a@posting.google.com: > > > When I load this program in the IDE using the F7 Build Project key, my > > SYSCON and WAIT registers get trashed. I have traced the problem to a > > section of the library initialization in "__lib_setup_heaps" in the > > section with the heading "loop_thru_heaps". After fairly large number > > of iterations, SYSCON and WAIT get overwritten, usually with > > 0x00000000. > > Did you define any heaps? You need a small amount of space in that section > to satisfy one iteration of the initializer loop. It's been a long time > since I looked at it so I don't recall in detail how much you need, but I > think it was 4-6 words of zero.The following is the heap sections of my ldf. ... seg_heap { TYPE(DM RAM) START(0x0000ddb9) END(0x0000deff) WIDTH(32) } ... heap { // allocate a heap for the application ldf_heap_space = .; ldf_heap_length = MEMORY_SIZEOF(seg_heap); ldf_heap_end = ldf_heap_space + ldf_heap_length - 1; } > seg_heap
I finally got the SYSCON overwrite problem fixed. The label ___lib_end_of_heap_descriptions in "seg_init.asm" was not getting placed in memory but was being eliminated. I had to put the following in my init code so that the variable was used and not eliminated : .extern ___lib_end_of_heap_descriptions ; .global _Init_DSP; _Init_DSP: leaf_entry r0 = pm(___lib_end_of_heap_descriptions) ; This is a dummy that I don't do anything with but it eliminated the problem. The problem with the library is that the label CAN be eliminated. Depending on the state of memory after a reset, the library heap loader may or may not find what it considers a "valid heap int" section. sholle@link-comm.com (Steve Holle) wrote in message news:<ba83847d.0403041413.57c4860a@posting.google.com>...> I have a problem I'm hoping someone can help me with. I have an > ADSP-20165L system with external SRAM and have moved the $C_CPP_LIBS > to SRAM as shown in the snip from my ldf below: > > ... > $DEF_LIBS = libdsp.dlb; > $C_CPP_LIBS = libc.dlb, libcpp.dlb, libcpprt.dlb, libio.dlb; > $LIBRARIES = $DEF_LIBS, $C_CPP_LIBS; > ... > seg_pm_sdram { TYPE(PM RAM) START(0x00020000) END(0x00027fff) > WIDTH(32) } > seg_dm_sdram { TYPE(DM RAM) START(0x00030000) END(0x0005ffff) > WIDTH(32) } > > SECTIONS > { > ... > // .text output section > seg_pm_sdram > { > // INPUT_SECTIONS( $C_CPP_LIBS(seg_pmco) ... ) > INPUT_SECTIONS( $C_CPP_LIBS(seg_pmco) ... ) > } > seg_pm_sdram > > Ignore the sdram labels and substitute sram as this system has no > sdram. > > When I load this program in the IDE using the F7 Build Project key, my > SYSCON and WAIT registers get trashed. I have traced the problem to a > section of the library initialization in "__lib_setup_heaps" in the > section with the heading "loop_thru_heaps". After fairly large number > of iterations, SYSCON and WAIT get overwritten, usually with > 0x00000000. > > Any ideas?
