When working with complex project with multiple dependencies in Analog Devices VDSP, it is necessary to include the project group file into version control. However, as VDSP automatically updates the time/date record inside the group file at every session, it causes the annoying conflicts at version control all the time. Is there a good way to avoid this type of behavior? We are using SVN. VLV
VDSP and version control
Started by ●November 14, 2009
Reply by ●November 14, 20092009-11-14
Vladimir Vassilevsky <nospam@nowhere.com> writes:> When working with complex project with multiple dependencies in Analog > Devices VDSP, it is necessary to include the project group file into > version control. However, as VDSP automatically updates the time/date > record inside the group file at every session, it causes the annoying > conflicts at version control all the time. Is there a good way to > avoid this type of behavior? We are using SVN.Yes, avoid VDSP and make your own build system. -- Randy Yates % "Though you ride on the wheels of tomorrow, Digital Signal Labs % you still wander the fields of your mailto://yates@ieee.org % sorrow." http://www.digitalsignallabs.com % '21st Century Man', *Time*, ELO
Randy Yates wrote:> Vladimir Vassilevsky <nospam@nowhere.com> writes: > >> When working with complex project with multiple dependencies in Analog >> Devices VDSP, it is necessary to include the project group file into >> version control. However, as VDSP automatically updates the time/date >> record inside the group file at every session, it causes the annoying >> conflicts at version control all the time. Is there a good way to >> avoid this type of behavior? We are using SVN. > > Yes, avoid VDSP and make your own build system.There are many to choose from. Browse http://www.google.com/search?q=version+control+software+comparison Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Sat, 14 Nov 2009 13:58:40 -0500, Randy Yates wrote:> Vladimir Vassilevsky <nospam@nowhere.com> writes: > >> When working with complex project with multiple dependencies in Analog >> Devices VDSP, it is necessary to include the project group file into >> version control. However, as VDSP automatically updates the time/date >> record inside the group file at every session, it causes the annoying >> conflicts at version control all the time. Is there a good way to avoid >> this type of behavior? We are using SVN. > > Yes, avoid VDSP and make your own build system.This helps to make you immune from the egregious changes that IDE writers always want to make, it gives you far more control over 3rd-party tools (for instance if you want to generate signal tables or FPGA images in 'c' files, or if you want to post-process your hex files), and it lets you use Make, the Only Sensible Build Tool. -- www.wescottdesign.com
Tim Wescott <tim@seemywebsite.com> writes:> On Sat, 14 Nov 2009 13:58:40 -0500, Randy Yates wrote: > >> Vladimir Vassilevsky <nospam@nowhere.com> writes: >> >>> When working with complex project with multiple dependencies in Analog >>> Devices VDSP, it is necessary to include the project group file into >>> version control. However, as VDSP automatically updates the time/date >>> record inside the group file at every session, it causes the annoying >>> conflicts at version control all the time. Is there a good way to avoid >>> this type of behavior? We are using SVN. >> >> Yes, avoid VDSP and make your own build system. > > This helps to make you immune from the egregious changes that IDE writers > always want to make, it gives you far more control over 3rd-party tools > (for instance if you want to generate signal tables or FPGA images in 'c' > files, or if you want to post-process your hex files), and it lets you > use Make, the Only Sensible Build Tool.Amen, brother! However, it can be a daunting task. Fortunately I've evolved a system over the last 10 years that seems to work well across multiple platforms. -- Randy Yates % "Maybe one day I'll feel her cold embrace, Digital Signal Labs % and kiss her interface, mailto://yates@ieee.org % til then, I'll leave her alone." http://www.digitalsignallabs.com % 'Yours Truly, 2095', *Time*, ELO
Reply by ●November 15, 20092009-11-15
> >When working with complex project with multiple dependencies in Analog >Devices VDSP, it is necessary to include the project group file into >version control. However, as VDSP automatically updates the time/date >record inside the group file at every session, it causes the annoying >conflicts at version control all the time. Is there a good way to avoid >this type of behavior? We are using SVN. > > >VLV >I still run into the same issue with another Windows IDE. Fortunately in my case, it's possible to usually know I didn't change anything important, and hit SVN revert before updating. Or you could figure out what location in the file is changing (hopefully a constant offset, or something obvious) and write a short program to overwrite it with the value from the conflicting revision. If anything other than the dates are changing, then you've got a mess. Differencing binary files is outdone in badness only by differencing undocumented binary files. One other option, never having used VDSP personally, *might* be to see if there's a way to import settings from a more sane format, and just import every time you load the project. No particularly good solution, as others hinted at...
