hi to all, I am using eZdsp TMS320LF2407(Spectrum incorporated) for project of power system harmonic suppression. I have created a sine wave generation program and created .out file from ccs.Can anybody please tell the procedure to download that .out file to the kit. Regards suresh
TMS320LF2407
Started by ●November 18, 2009
Reply by ●November 19, 20092009-11-19
On Nov 18, 12:28�pm, "sureshneyan" <sureshne...@gmail.com> wrote:> hi to all, I am using eZdsp TMS320LF2407(Spectrum incorporated) for project > of power system harmonic suppression. I have created a sine wave generation > program and created .out file from ccs.Can anybody please tell the > procedure to download that .out file to the kit. > > Regards > sureshHi Suresh, If the code is located in RAM menu: File/Load program, select .out file Though it is easier to go under Options/customize/program load and select "load program after buid" option If the code is located in FLASH menu: tools/On chip flash programmer - though you must have flash plugin installed Regards, Mitja
