C6711 dsk question
Started by flipdog March 3, 2004
Hello all,
I am learning how to program C6711 dsk with CCS 2.1 on an NT platform.  I
came across the following example from chassaing's book.  This is part of
the code
interrupt void c_int11()
   int   sample_data;
   sample_data = input_sample();
    ...do some filtering of sample_data here...
   output_sample(sample_data);
   buffer[i] = sample_data;
   i++;
   if(i==BUFFER_SIZE) i=0;
   return;
Right now I can play a wav file and plug the wav file directly into the dsk
audio input.  What I want to find out is how to send a wav file directly
from the host to the target instead of using a direct audio plug in as
mentioned. After preprocessing, I would like to save the filtered wave file.
How do I do that?  I flipped through chassaing's book but I couldn't find a
solution.  Would someone please inform me how to go about doing this?
Thanks in advance.
FD
Sorry folks,
I have to withdraw this question.  From TI tutorial, the answer my question
seems to lie within the understanding of the usage of RTDX.  I am working on
it.
Regards,
FD
"flipdog" <john.lai@worldnet.att.net> wrote in message
news:Wfm1c.68260$aH3.2089575@bgtnsc04-news.ops.worldnet.att.net...
> Hello all, > I am learning how to program C6711 dsk with CCS 2.1 on an NT platform. I > came across the following example from chassaing's book. This is part of > the code > > interrupt void c_int11() > { > int sample_data; > sample_data = input_sample(); > > ...do some filtering of sample_data here... > > output_sample(sample_data); > buffer[i] = sample_data; > i++; > if(i==BUFFER_SIZE) i=0; > return; > } > > Right now I can play a wav file and plug the wav file directly into the
dsk
> audio input. What I want to find out is how to send a wav file directly > from the host to the target instead of using a direct audio plug in as > mentioned. After preprocessing, I would like to save the filtered wave
file.
a
> solution. Would someone please inform me how to go about doing this? > > Thanks in advance. > FD > >
