Good morning to every one. . . I am very new to this forum and not much expert in DSP field too. . . I am trying to implement a IEEE paper named "A New Delayless Subband Adaptive Filtering Algorithm for Active Noise Control Systems" published in IEEE TRANSACTIONS ON AUDIO, SPEECH, AND LANGUAGE PROCESSING july 2009. I have not done any such projects before and so i am strugling where to start and how to implement the given details. This project is all about the following 1) A full-band filter that filters the input signal. 2) Decomposition of input and error signals into subbands. 3) Decimation in subbands. 4) Adaptive filters working in subbands. 5) A weight stacking method to combine all subbands weights into a full-band filter. These are the details of a filter specification given in the paper. Could any one please help me to implement this in the matlab please? x(n) is the input signal which is to be filtered into M subbands named X'k(n) where K ranges form 0 to M-1, using a analysis filter bank h(z) with a decimation factor D. Filter h(z) is given by h(z)=[ H0(z) ] | H1(z) | | . | | . | | . | [ Hm-1(z)] Where Hk(z) is the transfer function of Kth subband. Given the low pass prototype filter for filter banks is H0(z)=1+(Z)^-1+(Z)^-2+.......+(Z)^-M+1 The resulting filter bank is the simplest FIR filter perfect reconstruction filter bank which is made by Hk(z)=H0(z.exp(-j*2*pi*k/M)) with a frequency response of H0(exp(jw))={ M , when w=0; {exp(-j*w(M-1)/2sin(wM/2)/sin(w/2)) , otherwise; M is given about to be 16 D=M/4 For this proposed UDFT modulated filter banks, h(z) is defined by h(z) = (1/M)F*[1 , (Z)^-1 , (Z)^-2 ,. . ., (Z)^-M+1] (transpose) Where F is the DFT matix of order M. The central frequency of bandpass filters Hk(Z) are located at wk=2*pi*k/M for 0 ≤ k ≤ M-1. This filter can be realized by tapped delay line of length M followed by an inverse FFT block.
How to implement the filter give in Z transform using matlab
Started by ●January 28, 2010
Reply by ●January 28, 20102010-01-28
On 28 Jan, 14:13, "Rajkumar.R" <rraj...@gmail.com> wrote:> Good morning to every one. . ....> Could any one please help me to implement this in the matlab please?Helping with the programming would be consultancy work. Several people here might be both able and willing to help, but for a fee. If you have questions about the algorithms and details in the paper, by all means, we might help for free. But do expect to have to pay for hands-on help. Rune
