Hi, Can anyone please explain me the difference between pi/4 QPSK and pi/4 DQPSK? Recently i came accross these 2 termilogies. If You have any good reference explaining these 2 Modulation types, can you please share the same?
Difference between pi/4 QPSK and pi/4 DQPSK
Started by ●February 2, 2010
Reply by ●February 2, 20102010-02-02
On Tue, 02 Feb 2010 13:34:26 -0600, tanmoykar wrote:> Hi, > Can anyone please explain me the difference between pi/4 QPSK and pi/4 > DQPSK? Recently i came accross these 2 termilogies. If You have any good > reference explaining these 2 Modulation types, can you please share the > same?'True' QPSK encodes two bits as the absolute phase of the signal vs. the carrier -- so 0 degrees shift from carrier == 00, 90 degrees shift == 01, etc. Differential QPSK ('DQPSK') encodes two bits as the phase _jump_ of the signal -- so if the phase doesn't jump that means 00, +90 means 01, etc. (there are different mappings). QPSK enjoys a theoretical advantage, but in practice it requires some clever way to figure out what the carrier really is, or it requires a carrier reference on a side tone of some sort. DQPSK enjoys a practical advantage that if you lose carrier synchronization for a symbol or two recovery is much quicker. -- www.wescottdesign.com
On 2/2/2010 12:56 PM, Tim Wescott wrote:> On Tue, 02 Feb 2010 13:34:26 -0600, tanmoykar wrote: > >> Hi, >> Can anyone please explain me the difference between pi/4 QPSK and pi/4 >> DQPSK? Recently i came accross these 2 termilogies. If You have any good >> reference explaining these 2 Modulation types, can you please share the >> same? > > 'True' QPSK encodes two bits as the absolute phase of the signal vs. the > carrier -- so 0 degrees shift from carrier == 00, 90 degrees shift == 01, > etc. > > Differential QPSK ('DQPSK') encodes two bits as the phase _jump_ of the > signal -- so if the phase doesn't jump that means 00, +90 means 01, etc. > (there are different mappings). > > QPSK enjoys a theoretical advantage, but in practice it requires some > clever way to figure out what the carrier really is, or it requires a > carrier reference on a side tone of some sort.Yup. Usually the phase is resolved with the help of the FEC lock indicator, i.e., just try them all until one locks.> DQPSK enjoys a practical advantage that if you lose carrier > synchronization for a symbol or two recovery is much quicker.Yup. Often due to crappy oscillators with bad stability or phase noise or Doppler fading. -- Eric Jacobsen Minister of Algorithms Abineau Communications http://www.abineau.com
Reply by ●May 27, 20102010-05-27
Hi all, continuing on the difference previously stated, I just have a quick Q about the demodulation side of the the DQPSK, at the encoder im using the mapping: delta_phi(i) = phi(i) - phi(i-1) with QPSK mapping: B1 B2 phi 0 0 0 0 1 pi/2 1 1 pi 1 0 3*pi/2 and then i transmit only delta_phi across the channel,at the demodulator i use: phi(i) = delta_phi(i) + phi(i-1) Where I assume that phi(-1) = 0 at the transmitter and the receiver to get started initially. The mapping works perfectly when theres no channel effects, but say at the receiver, if theres 1 error in the received delta_phi, then everything received after that is wrong, looking at the demodulator, it makes sense since 1 wrong delta_phi(i) makes phi(i) incorrect and the incorrect phi(i) becomes an incorrect phi(i-1) in the next step, so even if delta_phi(i) is correct in the next step, phi(i) will still be incorrect, and its all downhill from there. I just dont see how to fix this problem at the moment, any insight would be greatly appreciated. Regards, Allan De Freitas
