Power and variance of Gaussian White Noise
Started by Arjun Admirer February 26, 2004
hi there
this is a newbie working on a signal denoising problem. i want to jam
a given signal with a white noise pulsed jammer such that the
effective jammer to signal ratio is some known value, say 30 db for
example.
to generate the wgn, i specify the variance in simulink for the
gaussian noise source.
what is the realtion between the variance (sigma) and power of white
gaussian noise?
could anyone guide to links to formulae for power for other
distributions?
regards, nityanand
Arjun Admirer wrote:
> hi there > > this is a newbie working on a signal denoising problem. i want to jam > a given signal with a white noise pulsed jammer such that the > effective jammer to signal ratio is some known value, say 30 db for > example. > > to generate the wgn, i specify the variance in simulink for the > gaussian noise source. > > what is the realtion between the variance (sigma) and power of white > gaussian noise?
I think you mean sigma^2 here.
> > could anyone guide to links to formulae for power for other > distributions? > > regards, nityanand
Try this: Gaussian_sigma = 0.5 * sqrt(2) * ( 10^(0.05 * noise_level_dB ) ) Good luck, OUP
In article 98a8c1a8.0402261015.41c8dc5d@posting.google.com, Arjun Admirer at
nityanand_misra@hotmail.com wrote on 02/26/2004 13:15:
the variance of a random process is the AC power. the mean square is the total, AC+DC, power. but the power of *true* white noise is infinite. that's because there is infinite area under the power spectrum for white noise. bandlimited white noise has finite power that is proportional to the bandwidth.
same as above. r b-j
