Real time MPEG-2 & MPEG-4 vedio encoding DSP
Started by Iqbal February 25, 2004
Dear,
could you tell me names of some real time MPEG-2 & MPEG-4  based vedio
encoding DSPs ?
Thanks
Iqbal
Iqbal wrote:
> Dear, > could you tell me names of some real time MPEG-2 & MPEG-4 based vedio > encoding DSPs ?
I guess it's a little bit too vague, since real-time depends on the CPU used. Anyway, you can try to look for "ffmpeg". bye, -- piergiorgio
Depends on a whole lot of things. The resolution required(varying
between anything from QCIF to HDTV), profile required(in case of MPEG4
can be SP,ASP,etc.), frame rate (usually between 15-30 fps) etc. Only
after knowing the above can a specific DSP be selected to support
real-time processing.
Regards
Piyush
tushariqbal@yahoo.com (Iqbal) wrote in message news:<2f696811.0402250644.5fd5cb13@posting.google.com>...
> Dear, > could you tell me names of some real time MPEG-2 & MPEG-4 based vedio > encoding DSPs ? > > Thanks > > Iqbal
