Hi, I wanted to estimate the position of something using data collected from an accelerometer. Now, I know this is a noisy process, so I wanted to use some filtering technique to get accurate position and velocity from just accelerometer readings. I was told that the Kalman Filter would do just the thing. I first decided to design and test a Kalman filter in Matlab and test it by making acceleration "data" (with added noise by a randn command). I would compare the Kalman estimated position to the actual position and compare it to a position estimate found by simply double integrating the noisy acceleration. However, when I implemented what I thought would be very simple into Matlab, the results did not seem to suggest any success. My Kalman estimated position was not very good and was just as bad as a doubly integrated acceleration. (The double integration is done by just doing a Riemann sum over my acceleration data twice). I'm using the same variables as those given in the explanation on Wikipedia's site http://en.wikipedia.org/wiki/Kalman_Filter First, I define a time vector of t = [0:.01:10] to be the time points in which I sample my acceleration. I then define an acceleration vector with something like acc = sin(t). I then make a noisy acceleration (which simulates accelerometer readings) by doing noisyAcc = acc + randn(1,1001). I want this to be the measurement data that I will be inputting into the Kalman Filter. So, I wanted to make sure I understood what my state matrices should be. My state variable, denoted x, is a 3 by 1 vector of position, velocity, and acceleration. I will be sampling every dt=.01 seconds (this is just because I define my time vector in matlab to be 0:.01:10). So, the state should evolve kinematically by the matrix F = [1 dt dt^2/d ; 0 1 dt; 0 0 1]. So, x_k = F* x_(k-1). I'm assuming no process noise for now. However, this doesn't seem to take into account the fact that the object is accelerating by its own drive. So, I figured there should be some input to change the acceleration. So, I added a B matrix given by B = [dt^2/2; dt; 1] which should account for the change in acceleration from the k-1 to the k stage. So, my evolution would then be x_k = F*x_(k-1) + B*(acc(k) - acc(k-1)) Where acc(k) is the k-th measured acceleration data point. But, these acceleration vectors are noisy, so I'm not sure this is the right thing to put here. I've also tried this without the B* term and my Kalman program similarly performs poorly. Next, my measurement matrix would be H = [0; 0; 1], as I'm measuring only acceleration. From here, I define everything exactly as wikipedia suggests with its equations to predict, calculate innovation, and update. For covariance updates, I use P = F*P*F' and I have an R = sigma^2 where sigma^2 is the standard deviation of the noise signal I input (this is calculated before the program is run). However, my Kalman estimated positions do not seem to do very well, and are often worse than if I just used a simple numerical integration. Any suggestions or hints on what I might have done wrong? I'm guessing I've made some mistake with my state evolution. Thanks!
Kalman Filter with an Accelerometer
Started by ●March 20, 2010
Reply by ●March 21, 20102010-03-21
Positron wrote:>Hi, I wanted to estimate the position of something using data collected >from an accelerometer.Is your orientation constant? How many axes of accelerometers do you have? Have you accounted for gravity and the various pseudoforces? I'll assume this is a simulation problem only, and that you've taken trivial solutions to these, but you'll eventually have to worry about these things in practice. (I answer that way because you've said almost nothing about your plant or sensors, so I assume you haven't chosen one.)>Now, I know this is a noisy process, so I wanted to >use some filtering technique to get accurate position and velocity from >just accelerometer readings. I was told that the Kalman Filter would do >just the thing.Accelerometers alone won't do you much good. You need something redundant, such as a decent plant model, other sensors, or, ideally, both.>I first decided to design and test a Kalman filter in Matlab and test itby>making acceleration "data" (with added noise by a randn command). I would >compare the Kalman estimated position to the actual position and compareit>to a position estimate found by simply double integrating the noisy >acceleration. However, when I implemented what I thought would be very >simple into Matlab, the results did not seem to suggest any success. My >Kalman estimated position was not very good and was just as bad as adoubly>integrated acceleration. (The double integration is done by just doing a >Riemann sum over my acceleration data twice). > >I'm using the same variables as those given in the explanation on >Wikipedia's site http://en.wikipedia.org/wiki/Kalman_Filter > >First, I define a time vector of t = [0:.01:10] to be the time points in >which I sample my acceleration. I then define an acceleration vector with >something like acc = sin(t). I then make a noisy acceleration (which >simulates accelerometer readings) by doing noisyAcc = acc +randn(1,1001).>I want this to be the measurement data that I will be inputting into the >Kalman Filter. > >So, I wanted to make sure I understood what my state matrices should be.My>state variable, denoted x, is a 3 by 1 vector of position, velocity, and >acceleration.I'm not sure if you can avoid making acceleration a state, but you might try.>I'm assuming no process noise for now. However, this >doesn't seem to take into account the fact that the object isaccelerating>by its own drive.When you move under your own control, you may add additional process noise in proportion to how much you think you're moving (assuming your plant has a tendency to move less when no control is applied, due to friction and such), since your movement mechanisms are presumably less certain than sitting still.>So, I figured there should be some input to change the >acceleration. So, I added a B matrix given by B = [dt^2/2; dt; 1] which >should account for the change in acceleration from the k-1 to the kstage.> >So, my evolution would then be > >x_k = F*x_(k-1) + B*(acc(k) - acc(k-1))You're differentiating an already-noisy signal (randn is ~ white gaussian; its derivative is even worse).>Where acc(k) is the k-th measured acceleration data point. But, these >acceleration vectors are noisy, so I'm not sure this is the right thingto>put here. I've also tried this without the B* term and my Kalman program >similarly performs poorly.B is usually related to a control input, not a measurement. You pick "B" according to how your motors, rockets, etc drive your platform in theory. If you're using the same measurements both for "B" and "H", I can't see that being helpful. Unless I'm missing something, this is likely to be the best area to work on next. Michael
Positron wrote:>I'm assuming no process noise for now.I meant to also point out that if you do that, your covariance will just decay towards zero. Process noise and sensor noise are supposed to oppose each other. As your filter becomes more confident of its estimate (as it will if the process noise is too low), it starts to essentially reject measurements. Michael
Hi! Thanks for the assistance so far. Yes, for now I am trying to do just a simple 1-D model with just a single accelerometer. You suggest avoiding using acceleration as a state. I have seen this in other examples where people have used the Kalman Filter for similar practices. I could redefine my state vector to just be position and velocity, and make my evolution matrix F = [1 dt; 0 1]. However, how would I add in the fact that the body (assume it's a car or something that can accelerate on its own) is accelerating? Is that just added in the measurement stage? Therefore, I would have x_k = F*x_(k-1) But, this doesn't seem to be including the addition of the acceleration at each state (which is measured by the accelerometer). If I remove acceleration as a state, how would I model the measurement? In my measurement state, I had y = z - H*x_k where z is the noisy acceleration measurement and H is the measurement matrix which was picking the acceleration out of my state vector. That is, H = [0; 0; 1]. If I remove acceleration as a state, how would I do this part? Acceleration wouldn't be in my state vector anymore, so what would H be? Am I in error thinking that I can use the Kalman Filter to accurately predict position when the car is accelerating on its own? Does it only work for situations where the acceleration is random white-Gaussian noise? Thanks for the help so far!
>Yes, for now I am trying to do just a simple 1-D model with just a single >accelerometer.You still need to know how your plant moves. Inertia, forces, etc.> >You suggest avoiding using acceleration as a state. I have seen this in >other examples where people have used the Kalman Filter for similar >practices. I could redefine my state vector to just be position and >velocity, and make my evolution matrix F = [1 dt; 0 1]. However, howwould>I add in the fact that the body (assume it's a car or something that can >accelerate on its own) is accelerating? Is that just added in the >measurement stage?That is really the smallest concern. The flip side of my point was that if you can't do it, don't worry about it.>If I remove acceleration as a state, how would I model the measurement?If your plant model were more complicated, it *may* make sense to take the portion of your F and B matrices giving the continuous-time velocity update (i.e., dv/dt) and use that. But, at the same time, it may be worse. Like I said, it's less important and you shouldn't focus on it yet until the filter at least appears to work some. The gain is not differentiating your accelerometer measurements, but the suggestion is not without its problems. Wait on this.>Am I in error thinking that I can use the Kalman Filter to accurately >predict position when the car is accelerating on its own?On its own? What does that mean? Newton's first law: "An object at rest tends to stay at rest and an object in motion tends to stay in motion with the same speed and in the same direction unless acted upon by an unbalanced force." (copied from a random google search)>Does it only work >for situations where the acceleration is random white-Gaussian noise?The state should not be noise to begin with. Have a look back at what I said about "B" in my first post. Now the noise *ought* to be white gaussian noise, but even then the filter is known to be somewhat robust in many situations. Michael
Sorry I've been rather unclear up to this moment! Thanks for your patience and willingness to help. I'm not an engineering student (just a curious math major!). When I said "it moves on its own" what I meant is a scenario like this: Imagine a car with a driver in it that can drive however he or she wishes. The car has an accelerometer attached to it. The goal is to determine purely from the accelerometer readings how far the car has traveled. So, the car moves simply using Newton's laws and kinematics. That's why I chose F =[1 dt dt^2/2 ; 0 1 dt; 0 0 1]. But, this ignores the actual acceleration that the driver seems to be able to choose. That's why I figured we would take measurements of acceleration. However, when the state evolves from x_k to x_(k+1) I need to factor in the new acceleration at the time step k+1. "You still need to know how your plant moves. Inertia, forces, etc." I'm unfamiliar with the word plant. Does that just refer to the body in question with the accelerometer attached to it? Or does this just mean the actual model itself? With respect to forces, the car has a driver, so accelerations occur at the whim of the driver. For my simple model, I'm assuming there are no other outside forces (although, later I will assume a bumpy road scenario so there will be some random Gaussian process noise). Does that make a bit more sense? Thanks again for the assistance!
Positron wrote:>Sorry I've been rather unclear up to this moment! Thanks for yourpatience>and willingness to help. I'm not an engineering student (just a curiousCuriosity is good, but you might also do some searching, too.>math major!). When I said "it moves on its own" what I meant is ascenario>like this: Imagine a car with a driver in it that can drive however he or >she wishes.So you're trying to work without measuring what the driver is doing, but, rather, the effects of what the driver is doing. Can you add a sensor to measure the positions of the pedals (or something closely related)? That's really the kind of thing that goes in the "B" and "u" terms. At the risk of overgeneralizing, the more information you give the filter, the better, and only giving it one piece of information is not a recipe for success, as you've found. I'd still expect some drift even then, but it'll be less, and you can cut it down if you can assume the car tends to stop on its own (somewhat level ground). If you're not able to connect to the car, you might at least postulate GPS, computer vision, odometry, or some other source of data. Is this a purely theoretical exercise, or are you actually going to try to implement it at some point? If it's just a theoretical exercise, you may want to try something a bit different (let me know, and I can give you some ideas to play around with to build intuition). Can you afford a book?>The car has an accelerometer attached to it. The goal is to >determine purely from the accelerometer readings how far the car has >traveled.The way you've posed the problem, it probably just won't work. The Kalman Filter is not magical. You may be able to improve your results slightly, but nothing better than applying a digital FIR or IIR filter to the data and doing your double integration. The nice thing about the Kalman Filter is its ability to combine information.> >So, the car moves simply using Newton's laws and kinematics. That's why I >chose F =[1 dt dt^2/2 ; 0 1 dt; 0 0 1]. But, this ignores the actual >acceleration that the driver seems to be able to choose.Yes, and the acceleration is usually a function of the system state. In this case, it is not. The fact that your filter has no idea what the driver chose is technically a violation of an assumption in the derivation of the filter, but that in and of itself isn't necessarily fatal in practice. It usually means that you add a lot of process noise to try to cover up what the driver is doing. I wouldn't necessarily expect the covariance to be a useful measure of how the filter is doing in that case, though you can certainly build intuition through simulation. Again, I don't think the Kalman Filter is really gaining you anything the way you're using it.>That's why I >figured we would take measurements of acceleration. However, when thestate>evolves from x_k to x_(k+1) I need to factor in the new acceleration atthe>time step k+1. > >"You still need to know how your plant moves. Inertia, forces, etc." > >I'm unfamiliar with the word plant. Does that just refer to the body in >question with the accelerometer attached to it? Or does this just meanthe>actual model itself?In this case, at a minimum, it refers to the car. You can also make it refer to the driver and the road, but that choice is not arbitrary, and depends on what you're doing. "plant" is one of the first terms you hit in controls theory, so I assumed that you'd have run into it in your reading on wikipedia and elsewhere. You apply a control input (u) to a plant (the system and/or a model of a system), and you measure outputs through sensors (y). There are internal states that are not usually directly observable, which we model as "x". The choice of "x" is usually not unique, but physical states like position, etc. are acceptable in this case. Sometimes the sensor data is fed through a transformation (usually with memory), back into the control input; this is basic feedback control of the plant, such as in a cruise control (which uses a measurement of speed, not acceleration).> >With respect to forces, the car has a driver, so accelerations occur atthe>whim of the driver. For my simple model, I'm assuming there are no other >outside forces (although, later I will assume a bumpy road scenario so >there will be some random Gaussian process noise).A bumpy road presents sensor difficulties, but ultimately has a [nearly?] zero-mean effect on the states. A grade in the road may violate assumptions about the plant: does your car come to a stop if you coast long enough?>Does that make a bit more sense?Yes, although I think you'll wind up frustrated if you follow this path without changing the problem statement any. Either in simulation or in practice, this is not really going to be pleasant without some changes. If you integrate white noise, you get a random walk, and if you integrate that, you get a random ramp. Have you seen graphs of realizations of those processes, or of their statistics? Try doing your double cumsum() you mentioned over 10000 of those randn() realizations, and plotting either all the traces, or, if MATLAB is being retarded about memory, just median, Q1, Q3 (quantile(), IIRC). The results are all over the place, no? And that's assuming no bias on the accelerometers. By measuring a quantity more closely related to what you want to estimate (such as position), even if your measurements are rare, you can try to keep those drifts in check. Michael
Positron wrote:> Hi, I wanted to estimate the position of something using data collected > from an accelerometer. Now, I know this is a noisy process, so I wanted to > use some filtering technique to get accurate position and velocity from > just accelerometer readings. I was told that the Kalman Filter would do > just the thing.It won't, at least not for real-world problems with real-world accelerometers. Even if you have a three-axis accelerometer, to do this in the real world would require that you also have a three-axis gyro, and that your gyros and accelerometers are inertial grade. Even then, the problem statement lacks any redundant data, so the Kalman filter will degenerate into a simple multiple-integration problem -- and you'll be completely wrong unless your initial position and orientation estimates are dead on.> I first decided to design and test a Kalman filter in Matlab and test it by > making acceleration "data" (with added noise by a randn command). I would > compare the Kalman estimated position to the actual position and compare it > to a position estimate found by simply double integrating the noisy > acceleration. However, when I implemented what I thought would be very > simple into Matlab, the results did not seem to suggest any success. My > Kalman estimated position was not very good and was just as bad as a doubly > integrated acceleration. (The double integration is done by just doing a > Riemann sum over my acceleration data twice).That's because if an accelerometer is your only input, then doubly-integrating it's output _is_ the optimal solution.> I'm using the same variables as those given in the explanation on > Wikipedia's site http://en.wikipedia.org/wiki/Kalman_Filter > > First, I define a time vector of t = [0:.01:10] to be the time points in > which I sample my acceleration. I then define an acceleration vector with > something like acc = sin(t). I then make a noisy acceleration (which > simulates accelerometer readings) by doing noisyAcc = acc + randn(1,1001). > I want this to be the measurement data that I will be inputting into the > Kalman Filter.Fair enough.> So, I wanted to make sure I understood what my state matrices should be. My > state variable, denoted x, is a 3 by 1 vector of position, velocity, and > acceleration. I will be sampling every dt=.01 seconds (this is just because > I define my time vector in matlab to be 0:.01:10). So, the state should > evolve kinematically by the matrix F = [1 dt dt^2/d ; 0 1 dt; 0 0 1]. So, > x_k = F* x_(k-1). I'm assuming no process noise for now. However, this > doesn't seem to take into account the fact that the object is accelerating > by its own drive. So, I figured there should be some input to change the > acceleration. So, I added a B matrix given by B = [dt^2/2; dt; 1] which > should account for the change in acceleration from the k-1 to the k stage. > > So, my evolution would then be > > x_k = F*x_(k-1) + B*(acc(k) - acc(k-1)) > > Where acc(k) is the k-th measured acceleration data point. But, these > acceleration vectors are noisy, so I'm not sure this is the right thing to > put here. I've also tried this without the B* term and my Kalman program > similarly performs poorly.Unless the accelerometer has significant dynamics (which it won't for your case, I think), you don't want to model the accelerometer state. Just take the accelerometer output as an input to a system.> Next, my measurement matrix would be H = [0; 0; 1], as I'm measuring only > acceleration. From here, I define everything exactly as wikipedia suggests > with its equations to predict, calculate innovation, and update. For > covariance updates, I use P = F*P*F' and I have an R = sigma^2 where > sigma^2 is the standard deviation of the noise signal I input (this is > calculated before the program is run). However, my Kalman estimated > positions do not seem to do very well, and are often worse than if I just > used a simple numerical integration. Any suggestions or hints on what I > might have done wrong? I'm guessing I've made some mistake with my state > evolution.With your two state system you will find that H = [0; 0], and it will become clear why the exercise of constructing a Kalman filter isn't sensible. Even with your system, if you go through the update matrices, I think you'll find that updating the acceleration state doesn't do anything significant to the velocity and positions states. Kalman filters make sense when you have redundant information (like acceleration plus a noisy position reading, or acceleration plus an occasional position reading), or when you are doing something like measuring position and attempting to estimate acceleration from it. Usually it is not immediately clear how to use the information you have to get an optimal -- or even sensible -- answer. This is what the Kalman filter provides. What it _doesn't_ do is cough up a magic filter that will extract data where there is no good data is to be found. I very much suspect that your _construction_ of a Kalman filter is fine, but your _choice_ of a Kalman filter is misinformed, because you don't have the redundant information you need in this case. Make a problem statement that gives you a reasonably good position measurement once every second or so, or gives you a really noisy position measurement continuously, and you'll find a lot of benefit to a Kalman filter. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Michael Plante wrote:> Positron wrote: >> I'm assuming no process noise for now. > > I meant to also point out that if you do that, your covariance will just > decay towards zero. Process noise and sensor noise are supposed to oppose > each other. As your filter becomes more confident of its estimate (as it > will if the process noise is too low), it starts to essentially reject > measurements.(Note: This is getting poured onto a USENET newsgroup, where retaining context is a very nice thing.) For the construction that he stated -- three states, one of which is the accelerometer state -- the accelerometer noise should be process noise. Then the velocity and position uncertainty will show up correctly. For the construction that I suggested (and that I think Michael did, too), with just velocity and position as states, and acceleration as an input, the output gain is always zero, the Kalman filter never really updates, and the velocity and position uncertainty will also evolve as expected. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Positron wrote: ...> With respect to forces, the car has a driver, so accelerations occur at the > whim of the driver. For my simple model, I'm assuming there are no other > outside forces (although, later I will assume a bumpy road scenario so > there will be some random Gaussian process noise). > > Does that make a bit more sense?It makes clear what you are leaving out. What will the accelerometer outputs be when the car is parked facing up hill? How many axes are you measuring? If fewer than three, what assumptions do you make. Be aware that the accelerometer outputs will have enough offset to saturate any integrators you may use in a discouragingly short time. Jerry -- Discovery consists of seeing what everybody has seen, and thinking what nobody has thought. .. Albert Szent-Gyorgi �����������������������������������������������������������������������
