On Apr 5, 5:29�pm, "Jan Simon" <matlab.THIS_Y...@nMINUSsimon.de> wrote:> Dear Luna! > > > I have a vector of real numbers in Matlab. How do I compress them? �Of > > course this has to be lossless, since I need to be able to recover > > them. > > > The goal is to study the Shannon rate and entropy of these real > > numbers, so I decide to compress them and see how much compression > > ratio I can have. > > > I don't need to write the result into compressed files, so those > > headers, etc. are just overhead for me which affect me calculating the > > Entropy... so I just need a bare version of the compress ratio... > > Michael Kleder's function compresses data in the memory with the zlib: > �http://www.mathworks.com/matlabcentral/fileexchange/8899 > > E.g. for sin(1:1e5) this saves 5% memory. 7-zip reduces the file by at least 25%. > > Good luck, JanSo how is this approach: I first write the floating numbers to a TEXT file, and then call Winzip or 7Zip from within Matlab and then measure the file size change before and after the compression, and then compute the ratio.
How do I compress an array of floating numbers in Matlab?
Started by ●April 2, 2010
Reply by ●April 6, 20102010-04-06
On Apr 5, 7:32�pm, TideMan <mul...@gmail.com> wrote:> On Apr 6, 9:29�am, "Jan Simon" <matlab.THIS_Y...@nMINUSsimon.de> > wrote: > > > > > Dear Luna! > > > > I have a vector of real numbers in Matlab. How do I compress them? �Of > > > course this has to be lossless, since I need to be able to recover > > > them. > > > > The goal is to study the Shannon rate and entropy of these real > > > numbers, so I decide to compress them and see how much compression > > > ratio I can have. > > > > I don't need to write the result into compressed files, so those > > > headers, etc. are just overhead for me which affect me calculating the > > > Entropy... so I just need a bare version of the compress ratio... > > > Michael Kleder's function compresses data in the memory with the zlib: > > �http://www.mathworks.com/matlabcentral/fileexchange/8899 > > > E.g. for sin(1:1e5) this saves 5% memory. 7-zip reduces the file by at least 25%. > > > Good luck, Jan > > An entirely different approach is "wavelet shrinkage". > Google it. > It's easy to do in Matlab if you have the wavelet toolbox. > I use the techniques for denoising and despiking, but I've never tried > to compress data with them. > I use Shannon entropy to figure out the optimum mother wavelet.Sounds good. I guess the question is how to decide the Shannon entropy for a sequence of floating numbers?
