On 21-05-2010 at 08:59:00 zs <zsolt.garamvolgyi@gmail.com> wrote: (...)> What I'm talking about is filter design and visualization: when > designing a filter, I think it's useful to see its actual response(...) And they are actual and precise. Fdatool generates digital filters coefficients. (...)> without taking 'secondary' effects into account.What do you mean, there is no secondary effects. They all are primary. (...)> (visualized) response being corrupted below -150 dB won't imply any > problems during realization,(...) Frequency response is just perfectly the same as later realization. (...)> but having a correct response in a larger > dynamic range gives insight on the filter design process:(...) Maybe you would like an analog filter. Then you should use proper tool for that. My best analog design tool is pen and paper. The all infinities I plot in my mind because I have only finite sheet of paper.> Zsolt-- Mikolaj
LPF butterworth filter question
Started by ●May 12, 2010
Reply by ●May 21, 20102010-05-21
