Audio Metering implementation
Started by moz July 3, 2010
Hi Everyone,
I could need a little help today.
I am currently implementing a software Audio Meter that visualizes the
signal in dB.
The signal is presented in form of a bar that fills up all the way to the
top if the signal reaches 0dBFS and is empty when it is below or equal
-60dBFS. The bar currently follows a linear approach, meaning that the
pixel difference between each unit is the same.
-80  -60   -40   -20    0
This all works great. I get there basically by building the RMS over a
window of x samples, convert the result to dB (via log function) and
calculate the pixel for the value on the x coordinate(where -80dB is 0% and
0dB is 100%) and fill the rectangle with color (every y millseconds).
In the next step I simply want to present the values in log scale where the
values are represented graphically like:
-20   -10  -7    -5    -3     -1    0     1     2     3
This is a typical VU Meter as found on many hardware(software)
implementations.
I do have a hard time with transforming the linear way to present the
signal to this log way. The main problem: How would I find the amount of
pixels I would need to present each value on this log scale ?
Next question then: How could I then implement specific scales like let's
say the K-20 scale or DIN45406 ?
Any help or pointers would be appreciated.
Thanks in advance,
Mozzak
moz wrote:
> Hi Everyone, > > I could need a little help today. > > I am currently implementing a software Audio Meter that visualizes the > signal in dB. > > The signal is presented in form of a bar that fills up all the way to the > top if the signal reaches 0dBFS and is empty when it is below or equal > -60dBFS. The bar currently follows a linear approach, meaning that the > pixel difference between each unit is the same. > > |-----|-----|-----|-----| > -80 -60 -40 -20 0 > > This all works great. I get there basically by building the RMS over a > window of x samples, convert the result to dB (via log function) and > calculate the pixel for the value on the x coordinate(where -80dB is 0% and > 0dB is 100%) and fill the rectangle with color (every y millseconds). > > In the next step I simply want to present the values in log scale where the > values are represented graphically like: > > |-----|-----|-----|-----|-----|-----|-----|-----|-----| > -20 -10 -7 -5 -3 -1 0 1 2 3 > > This is a typical VU Meter as found on many hardware(software) > implementations. > > I do have a hard time with transforming the linear way to present the > signal to this log way. The main problem: How would I find the amount of > pixels I would need to present each value on this log scale ? >
Strategy 1: Put the data into Excel, run a trendline on it which displays the formula for the trendline. Then invert that function. If not Excel, then choose your weapon of choice. Strategy 2: Define a breakpoint table and interpolate. To be a true VU meter, you also have to match VU meter ballistics. http://www.tonmeister.ca/main/textbook/node755.html
> Next question then: How could I then implement specific scales like let's > say the K-20 scale or DIN45406 ? > > Any help or pointers would be appreciated. > > Thanks in advance, > Mozzak > > >
-- Les Cargill
You must understand something about logarithms in order to express the signal magnitudes as logarithms.
Plot the signal without taking logs, then label the points with their (suitably scaled)logarithms. So -20 is the label for .01, -3 is the label for .707, +3 is the label for 1.4.4, etc. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
(snip)
Usual methods would be a lookup table or a loop comparing to breakpoints, exit the loop at the appropriate point. It depends somewhat on the available hardware. Discussed here not so long ago was how to do A (or other) weighting. Also, as someone else mentioned, balistics. -- glen
