hi I would be happy and thankful if anyone can help me with the following *what algorithm to use for vocal pitch detection *is it possible to implement it in a real time system using TMS320C50 hoping for your reply
Vocal pitch detection
Started by ●August 3, 2010
Reply by ●August 3, 20102010-08-03
On Aug 3, 8:43�am, "ash4work" <shyarebash@n_o_s_p_a_m.gmail.com> wrote:> hi > I would be happy and thankful if anyone can help me with the following > > *what algorithm to use for vocal pitch detection > *is it possible to implement it in a real time system using TMS320C50 > hoping for your reply*what algorithm to use for vocal pitch detection Most certainly US Patent 7124075 without any doubt (you are talking about one vocal, right ?) http://www.google.com/patents/about?id=dB97AAAAEBAJ&dq=7124075 *is it possible to implement it in a real time system using TMS320C50 Sure it is, if it's simplified and optimized Be sure to let us know about your success :-)
ash4work wrote:> hi > I would be happy and thankful if anyone can help me with the followingBe happy and don't stick your nose into the things that you have no clue about.> *what algorithm to use for vocal pitch detectionNormalized autocorrelation with upsampling to refine the result, or FFT harmonic peak matching.> *is it possible to implement it in a real time system using TMS320C50 > hoping for your replyIt is hardly possible since TMS320C50 was phased out some 20 years ago. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:> It is hardly possible since TMS320C50 was phased out some 20 years ago. > > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.comVlad, Of course it's "possible". The class notes go back that far!! Fred
Reply by ●August 4, 20102010-08-04
On Aug 3, 8:59=A0am, fatalist <simfid...@gmail.com> wrote:> On Aug 3, 8:43=A0am, "ash4work" <shyarebash@n_o_s_p_a_m.gmail.com> > wrote: > > > hi > > I would be happy and thankful if anyone can help me with the following > > > *what algorithm to use for vocal pitch detection > > *is it possible to implement it in a real time system using TMS320C50 > > hoping for your reply > > *what algorithm to use for vocal pitch detection > > Most certainly US Patent 7124075 without any doubt (you are talking > about one vocal, right ?) > > =A0http://www.google.com/patents/about?id=3DdB97AAAAEBAJ&dq=3D7124075 > > *is it possible to implement it in a real time system using TMS320C50 > > Sure it is, if it's simplified and optimized > > Be sure to let us know about your success :-)Vlad, weren't you going to be greeting Dmitry? r b-j
>> *is it possible to implement it in a real time system using TMS320C50 >> hoping for your reply > >It is hardly possible since TMS320C50 was phased out some 20 years ago.Don't exaggerate. This datasheet http://focus.ti.com/lit/ds/symlink/tms320c50.pdf was last updated in 1996. In the early 1990s the TMS320c50 was a major platform for V.34 modems, and into the late 90s a lot of V.90 modems were based on it. Steve
steveu <steveu@n_o_s_p_a_m.coppice.org> wrote: [Attributions lost] wrote,>>> *is it possible to implement it in a real time system using TMS320C50 >>> hoping for your reply >> >>It is hardly possible since TMS320C50 was phased out some 20 years ago. > >Don't exaggerate. This datasheet >http://focus.ti.com/lit/ds/symlink/tms320c50.pdf was last updated in 1996. >In the early 1990s the TMS320c50 was a major platform for V.34 modems, and >into the late 90s a lot of V.90 modems were based on it.Does this processor still exist as a core, or has it been completely sunsetted? S.
