On Aug 16, 10:58�am, "Ronaldo Souza" <nos...@nospam.org> wrote:> Can anyone recommend a good resampling lib? I need to handle rather > small buffers (100s of Ks of signed 16 bits) but also really long > streams, often covering 24+ hours @250sps, so speed is important. > > BTW, tipically I'll be downsampling from 250sps to 200sps, but there > will be other scenarios within the range 100sps <= In/Out sampling freq > <= 5000sps.You can take this very short simple Tiny Basic code for windowed-Sinc resampling, and optimize as needed. http://www.nicholson.com/rhn/dsp.html#3 Common optimizations include using a cache, or table lookup, or table interpolation for the windowed-Sinc function instead of (slowly) recalculating it for every tap for every point. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Resampling libs
Started by ●August 16, 2010
Reply by ●August 16, 20102010-08-16
> Tim Wescott wrote: > > Applying a library like Secret Rabbit Code blindly may work, and it > may not. If it does work, you're lucky. If it doesn't work, and it > breaks in the lab, you're a lot more lucky than if it breaks all over > a customer. > So try it, test the heck out of it, and keep your fingers crossed.I'm painfully aware of this and believe me, my fingers are crossed so tightly that I might get gangrene or something.> There's quite a few regulars in this group that consult; if it breaks > in a way that convinces the powers that be that it needs a fix in a > hurry you've got some experts available to trade money for fixes. Or > you can ask all the background questions, and we'll help you get > through it slowly.IMHO, consulting with somemone like Vladimir would be not only the correct choice, but also the best bang for the buck, but I'm "just" a tech guy and "have no understanding of our financial problems..." so, I'll give it a try and if (when?) it all tumbles down, I'll have to frame the problem from a $ POV, so they'll understand.> Get Rick Lyons's book ("Understanding Digital Signal Processing"). > If you can get through it fast enough then maybe by the time the > algorithm breaks you'll know why and can fix it.Thanks. <browsing Amazon...> Best regards, Ronaldo
> Ron N. wrote: > You can take this very short simple Tiny Basic code for > windowed-Sinc resampling, and optimize as needed. > http://www.nicholson.com/rhn/dsp.html#3 > Common optimizations include using a cache, or table lookup, > or table interpolation for the windowed-Sinc function instead > of (slowly) recalculating it for every tap for every point.Thanks a bunch, Ron. Best Regards, Ronaldo
