hi suppose you have a interpolation filter (with interpolating factor=3). now,how can i implement this filter in assembly language with only 3 cycles?
implementing interpolation filter
Started by ●September 23, 2010
Reply by ●September 23, 20102010-09-23
On Sep 23, 1:18=A0pm, "mahsad" <mahdi_kbm@n_o_s_p_a_m.yahoo.com> wrote:> > suppose you have a interpolation filter (with interpolating factor=3D3). > now,how can i implement this filter in assembly language with only 3 > cycles?perhaps, in 3 instruction cycles, you can perform 0th-order interpolation and copy each input sample into 3 adjacent output samples. dunno how many would call a zero-order hold much of an interpolator, but it is. sorta. r b-j
On Sep 23, 2:40�pm, robert bristow-johnson <r...@audioimagination.com> wrote:> On Sep 23, 1:18�pm, "mahsad" <mahdi_kbm@n_o_s_p_a_m.yahoo.com> wrote: > > > > > suppose you have a interpolation filter (with interpolating factor=3). > > now,how can i implement this filter in assembly language with only 3 > > cycles? > > perhaps, in 3 instruction cycles, you can perform 0th-order > interpolation and copy each input sample into 3 adjacent output > samples. > > dunno how many would call a zero-order hold much of an interpolator, > but it is. �sorta. > > r b-jFor a generic signal, it has real bad imaging. Dirk
On 9/23/2010 10:18 AM, mahsad wrote:> hi > suppose you have a interpolation filter (with interpolating factor=3). > now,how can i implement this filter in assembly language with only 3 > cycles? >Would you care to say what that filter *is*? Or, is it up to us? Fred
Reply by ●September 24, 20102010-09-24
On Sep 23, 10:18�am, "mahsad" <mahdi_kbm@n_o_s_p_a_m.yahoo.com> wrote:> hi > suppose you have a interpolation filter (with interpolating factor=3). > now,how can i implement this filter in assembly language with only 3 > cycles?You haven't said whether you mean 3 cycles per input sample or 3 cycles per output sample. r b-j has suggested an answer for the former. I'll suggest a box car filter for the latter. Dale B. Dalrymple
On Sep 23, 9:33�pm, dbd <d...@ieee.org> wrote:> On Sep 23, 10:18�am, "mahsad" <mahdi_kbm@n_o_s_p_a_m.yahoo.com> wrote: > > > hi > > suppose you have a interpolation filter (with interpolating factor=3). > > now,how can i implement this filter in assembly language with only 3 > > cycles? >.> You haven't said whether you mean 3 cycles per input sample or 3 .> cycles per output sample. .> r b-j has suggested an answer for the former. .> I'll suggest a box car filter for the latter. On further thought, the first two observations seem reasonable. The third seems to be a delusion, (perhaps brought on by overmuch contemplation of Rick Lyon's samples on a ruler analogy in another thread) unless you can scale an input and (+or-) accumulate in a single cycle. And this takes advantage of Fred's point that the interpolation filter has not been specified in your (homework?) problem. Dale B. Dalrymple
