uli.brueggemann@freenet.de (Uli Brueggemann) wrote in message news:<c77c52c1.0411030617.50bef889@posting.google.com>...> Hello Rune, > > > I am not completely sure what you mean here, I think you mean what I > > would term "mixed phase". Minimum phase has nothing to do with causality, > > since this aspect of the phase response is giverned by zeros in the > > transfer function. Causality is caused by the poles of the transfer > > function being located inside the unit circle. A completely different > > thing. > > Linear phase filters with the symmetric structure are described e.g. > in dspguide as non-causal. If you consider the center as zero then the > left sided taps are negative. This cannot happen in nature of course.Nope. What you describe is a zero phase filter. Causal linear phase filters can easily be implemented.> > > I read that the > > > minimum phase extraction can also be done by some kind of Hilbert > > > transform. After applying a FFT to the result I expect to be able to > > > calculate again magnitude and minimum phase response. > > > > Where did you read that? The "easy" way of finding a minimum phase > > response to your system, is to use an AR method to model your system. > > This will produce a system filter that is minimum pase. The problem > > is that many physical systems are mixed phase, so that these naive > > ideas don't always work. There was a couple of guys who investigated > > mixed/phase parameters a few years ago, try to search for authors > > Milton and Ursin in the seismics literature. > > > > in a book about loudspeaker measurements of d'Appolito. > In comparison to the filter design here we get the impulse response > from a measurement. The room response contains now a minimum phase and > an excessive phase, maybe we can say in total a mixed phase. I want to > extract the minimum phase. Several audio measurement software packages > can do it, but I don't know how. > > What is an AR method?It's a somewhat advanced method for representing measured data in terms of minimum phase filters. Learning these types of methods usually requires an at least one semester long intro course on DSP. I haven't heard of anyone without a degree in statistics or maths who have read up on these things outside a course. Rune
Minimum phase vice versa minimum phase
Started by ●November 2, 2004
Reply by ●November 4, 20042004-11-04
