Hello Randy, Then, could you provide a reference/s by which complex sampling is defined? I am interested in understanding well the relationship between a REAL signal (the signal which flights over the air), complex sampling and Nyquist theorem. I am interested in practical cases, since I seem to understand that complex sampling is carried out for a real signal that initially meets the even parity in the frequency domain (its module has a simmetry respect positive and negative frequencies). For example, many receivers implement I/Q demodulation obtaining a baseband representation of a passband signal (e.g., QAM demodulation). Cheers, M>On 12/05/2010 07:54 AM, MRR wrote: >> Thanks a lot for this debate. >> I continued this issue in wikipedia and the article "sampling" havebeen>> modified. One of the editors has added "complex sampling", which may be >> useful for understanding how the demodulation with complex baseband >> representation is carried out. >> >> Here you are the link: >> http://en.wikipedia.org/wiki/Sampling_%28signal_processing%29 >> >> Cheers, >> >> M > >The definition of complex sampling in that article is >not correct. The real and imaginary components of a >complex signal are not required to be related. Complex >sampling is not necessarily of Hilbert transform pairs. > >--Randy > >
Complex baseband signal. Inphase-Quadrature data
Started by ●November 7, 2010
Reply by ●December 5, 20102010-12-05
On 12/05/2010 11:49 AM, MRR wrote: > Hello Randy, > > Then, could you provide a reference/s by which complex sampling is defined? I couldn't find a good one on my bookshelf. It may be one of those things that are so basic folks don't think about defining it precisely. My best shot would be this: Complex Sequence: A sequence of samples x[n] where x[n] \in C and n \in Z. Note that "\in" is the set "element of" operator, and "C" is the set of complex numbers and "Z" is the set of integers. > I am interested in understanding well the relationship between a REAL > signal (the signal which flights over the air), complex sampling and > Nyquist theorem. > I am interested in practical cases, since I seem to understand that complex > sampling is carried out for a real signal that initially meets the even > parity in the frequency domain (its module has a simmetry respect positive > and negative frequencies). For example, many receivers implement I/Q > demodulation obtaining a baseband representation of a passband signal > (e.g., QAM demodulation). Since there are very few (if any, but that could probably be debated) real-world complex signals, complex signals are derived from real signals as you have stated, usually (at least in signal processing) either by Hilbert transform or by quadrature downconversion. -- Randy Yates % "My Shangri-la has gone away, fading like Digital Signal Labs % the Beatles on 'Hey Jude'" mailto://yates@ieee.org % http://www.digitalsignallabs.com % 'Shangri-La', *A New World Record*, ELO
Reply by ●June 4, 20122012-06-04
Nice to see that 2 years after this question can be completed by myself. Hope it helps to someone else. http://www.dsprelated.com/showmessage/172642/1.php
