Recurrence in the observation equation
Started by lanbaba January 20, 2011
Usually a Kalman filter can be applied to a system described by the
following equations:
X[k] = A*X[k-1] + W[k] ... (1)
Y[k] = C*X[k] + V[k] ... (2),
where (1) is the dynamic equation with the state X[k] and process noise
W[k], and (2) is the observation equation with the observation noise V[k].
The only dynamic is in the difference equation (1). Now, I'm reading a
paper on the Kalman filter application, where the observation Y[k] in a
specific application is subject to a recurrence relation too. In
particular, the observation equation reads
Y[k] = C*X[k-1] + V[k] ... (3).
I'm wondering if the classic Kalman filter still applies to the system
described by (1) and (3). If not, hot to adapt the Kalman filter? Does the
adapted Kalman filter have a specific name? Any hints of literature on this
issue are highly appreciated. In the paper that I'm reading these points
are not treated but only a classic Kalman filter is used.
On Jan 20, 8:30&#4294967295;pm, "lanbaba" <lanbaba@n_o_s_p_a_m.gmx.ch> wrote:
> Usually a Kalman filter can be applied to a system described by the > following equations: > X[k] = A*X[k-1] + W[k] ... (1) > Y[k] = C*X[k] + V[k] ... (2), > where (1) is the dynamic equation with the state X[k] and process noise > W[k], and (2) is the observation equation with the observation noise V[k]. > The only dynamic is in the difference equation (1). Now, I'm reading a > paper on the Kalman filter application, where the observation Y[k] in a > specific application is subject to a recurrence relation too. In > particular, the observation equation reads > Y[k] = C*X[k-1] + V[k] ... (3). > > I'm wondering if the classic Kalman filter still applies to the system > described by (1) and (3). If not, hot to adapt the Kalman filter? Does the > adapted Kalman filter have a specific name? Any hints of literature on this > issue are highly appreciated. In the paper that I'm reading these points > are not treated but only a classic Kalman filter is used.
It's the same. the original equation is X(k)=AX(k-1) whereas it is usually quoted as X(k+1)=AX(k). So you estimate the delayed state instead, so what? Hardy
Let [ A 0 ] A_n = [ ] [ I 0 ] C_n = [ 0 C ] Then you'll find that you're back to a regular old Kalman filter. Since you're only seeing one delay you should be able to rearrange the normal Kalman order of operations to get the second case for free: instead of doing the Kalman as prediction -> correction -> take X[k], do the Kalman as correction (from last time) -> prediction -> take X[k]. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
