My favorite one-pass laser is the nitrogen-gas laser described as a home project in Scientific American's "The Amateur Scientist" monthly column. The version described produced "a piece of light the size and shape of a broomstick." Actually, two pieces, one out of each end. My modified design reduced the back radiation to insignificance. Jerry
Re: modulation, bit rate, lasers and diodes sources
Started by ●January 24, 2011
Reply by ●January 25, 20112011-01-25
On Jan 24, 3:15�pm, Jerry Avins <j...@ieee.org> wrote:> My favorite one-pass laser is the nitrogen-gas laser described as a home project in Scientific American's "The Amateur Scientist" monthly column. The version described produced "a piece of light the size and shape of a broomstick." Actually, two pieces, one out of each end. My modified design reduced the back radiation to insignificance. > > JerryThat was a great article! I recall it made a gigawatt pulse with a nanosecond duration. The authors were measuring distances to clouds during the daytime by measuring the round trip times for pulses to the clouds and back. I thought the cleverest part of the design was their way to quickly switch on the voltage across the nitrogen column by using a spark gap to quickly bleed off half of the charge! Cool that you built one. Did you use it to measure distances? Clay
