On Tuesday, January 25, 2011 9:35:52 AM UTC-5, Clay wrote: ...> Cool that you built one. Did you use it to measure distances?No. I tried to burn holes. All I succeeded in doing was cracking lenses. By placing the spark gap toward one end of the metalized Teflon, I wasted little energy in the backward direction. Jerry
Re: modulation, bit rate, lasers and diodes sources
Started by ●January 25, 2011
Reply by ●January 25, 20112011-01-25
On Jan 25, 11:21�am, Jerry Avins <j...@ieee.org> wrote:> On Tuesday, January 25, 2011 9:35:52 AM UTC-5, Clay wrote: > > � ... > > > Cool that you built one. Did you use it to measure distances? > > No. I tried to burn holes. All I succeeded in doing was cracking lenses. By placing the spark gap toward one end of the metalized Teflon, I wasted little energy in the backward direction. > > JerryThat makes sense since now your electric wave is just ahead of the optical one. And that happens mostly in one direction. Clay
