Hi, I am totally new to Q formats, and need to do the following: Multiply a unsigned 16bith number by a decimal number < 1. For example: 30,000 * .378 = 11,340 How do I do this in a 16 bit fixed point uP with hardware multiplier The uP has the capable of doing 16x16 signed and unsigned multiplication resulting in a 32bit number. 1. How do I convert a decimal number (0.378 for example) into Q15 format? 2. How do I do the multiplication? 3. How do I convert the final 32 bit number back to the equivalent 16 bit number? Thanks Stephen
How do I multiply using Qformat?
Started by ●February 4, 2004
Reply by ●February 5, 20042004-02-05
stephendeese@hotmail.com (stevo) wrote in message news:<25cad608.0402041515.26388489@posting.google.com>... Hello Stephen, 1. How do I convert a decimal number (0.378 for example) into Q15 format? In Q15 format the input(X) must be between -1 and 0.999. For positive number ie 1>X>0 then X*2^15; For negative number ie X<0 then 2^16+X*2^15 For X>1 then X=2^15; 2. How do I do the multiplication? Is the number 30,000 result of Q15 format then u can multiply if not u cannot multiple 30,000 with 0.378. 3. How do I convert the final 32 bit number back to the equivalent 16 bit number? If u have two 1.15 number the result is 2.30 format. left shift one bit to get 1.31 format and u can take MSB 16 bit to get the result. regards praveen
Reply by ●February 6, 20042004-02-06
praveenkumar1979@rediffmail.com (praveen) wrote in message news:<ff8a3afb.0402042131.48aa1cce@posting.google.com>...> stephendeese@hotmail.com (stevo) wrote in message news:<25cad608.0402041515.26388489@posting.google.com>... > Hello Stephen, > > 1. How do I convert a decimal number (0.378 for example) into Q15 > format? > In Q15 format the input(X) must be between -1 and 0.999. > For positive number ie 1>X>0 then X*2^15; > For negative number ie X<0 then 2^16+X*2^15 > For X>1 then X=2^15; > > > 2. How do I do the multiplication? > Is the number 30,000 result of Q15 format then u can multiply if not u cannot > multiple 30,000 with 0.378. > > 3. How do I convert the final 32 bit number back to the equivalent 16 > bit number? > If u have two 1.15 number the result is 2.30 format. left shift one bit to get > 1.31 format and u can take MSB 16 bit to get the result. > > regards > praveenHi Just wanted to mention that you have to do signed multiplication between two Q15 numbers to geta Q30 product . As Praveen mentioned if 30,000 is a Q15 represented number then signed multiplication of 30,000(Q15 and .378 in Q15 would result in a fraction in Q30... This must be pretty obvious but when doing these things in filter implementation this might be the difference in having a round off error or no round off error Regards Nithin
