hello when i try to connect to a "F28335" an error appear in code composer studio that says: Error connecting to the target: Error 0x80000240/-604 Fatal Error during: Initialization, OCS, This error was generated by TI's USCIF driver. SC_ERR_LIB_ANY_LOAD <-604> A required dynamic library could not be installed. The attempt to load or install the library failed. what should i do? would some body please help me? regards
TI's USCIF driver
Started by ●February 19, 2011
Reply by ●February 20, 20112011-02-20
In article <o_OdncBCsIHFrv3QnZ2dnUVZ_oWdnZ2d@giganews.com>, "mamad13e" <mohammad66.ebrahimi@n_o_s_p_a_m.gmail.com> wrote:> when i try to connect to a "F28335" an error appear in code composer studio > that says: > Error connecting to the target: > Error 0x80000240/-604 > Fatal Error during: Initialization, OCS, > This error was generated by TI's USCIF driver. > > SC_ERR_LIB_ANY_LOAD <-604> > A required dynamic library could not be installed. > The attempt to load or install the library failed. > what should i do? > would some body please help me? > regardsI recommend the Texas Instruments E2E (Engineer to Engineer) forums. Not that you won't get any answer here, but TI should be more likely to support their products (F28355 and CCS) there. You also have the benefit of non-TI engineers there who might answer. Brian Willoughby Sound Consulting
