Say you have two signals, x and y, where y is the output of an unknown FIR filter. The only thing which is "known" about the FIR filter is that it has N filter coefficients. The above relates to acoustic echo cancellation for speech signals sampled at 8kHz. I guess you can call it a channel estimation problem? Or a deconvolution problem? I don't know.... Anyways....As a pre-liminary experiment I tried the following (in MATLAB): clc close all clear all N = 40; x = randn(1,100); b = fir1(N-1,0.9); y = filter(b,1,x); est_b = filter([y zeros(1,N-1)], x, [1 zeros(1,N-1) zeros(1,150)]); figure subplot(3,1,1) plot(x) subplot(3,1,2) plot(y) subplot(3,1,3) plot(b) hold on plot(est_b(1:N),'r--') drawnow The estimate est_b of the filter coefficients b is good, but sometimes it fails.. Can anybody explain why this happens? I wasn't able to see a pattern for the failures. Another question to you is: Which algorithm would you choose for an adaptive acoustic echo canceller for an embedded platform? There are probably lots of factors to consider, but just give me the names of a couple of algorithms so I can read about them. Thank you.
Which algorithm would you choose?
Started by ●April 8, 2011
Reply by ●April 10, 20112011-04-10
I think what you are running into is that there are conditions on the origi= nal data x, and the filter b that must be met for the channel identificatio= n to work. Think about this as solving a set of linear equations, then ther= e must be some conditions under which the system is ill conditioned. A naive example is when x is all zeros. Then you have no hope of recovering= the original filter. More generally, there are a set conditions on x and b= that must be met for b to be recoverable. Blind deconvolution literature t= alks about "source diversity." I'm a bit rusty with the details, but it's s= omething along the lines of requiring the source to have no nulls in its sp= ectrum. Chris
Reply by ●April 11, 20112011-04-11
On Apr 8, 9:20=A0pm, John McDermick <johnthedsp...@gmail.com> wrote:> Say you have two signals, x and y, where y is the output of an unknown > FIR filter. The only thing which is "known" about the FIR filter is > that it has N filter coefficients.Wrong problem statement. You will need to know (or assume) something more, like that the process under study is an AR process, a sum-of-sines process, or something like that. In these cases the best you can come up with is a *limit* on N, not the exact parameter. ...> Can anybody explain why this happens? > > I wasn't able to see a pattern for the failures.The pattern is that you use a defunct algorithm.> Another question to you is: Which algorithm would you choose for an > adaptive acoustic echo canceller for an embedded platform? There are > probably lots of factors to consider, but just give me the names of a > couple of algorithms so I can read about them.Read the book "Adaptive Filters" by Haykin. Rune
