On Apr 6, 10:02=A0pm, Tim Wescott <t...@seemywebsite.com> wrote:> On 04/05/2011 11:27 PM, Muhammed Shafi wrote: > > > Hi All, > > > =A0 First of all let me thank you all for your valuable solutions. If I > > go for Upsampling( Interpolation) i will have to fit some data based > > on the previous data . Am i right? > > Yes, kind of. =A0Strictly speaking, interpolation means that you're takin=g> data both before and after the point that you're interpolating, which > means that you have to allow some delay into your resampling process. > Taking data that is strictly before the point you're generating is > extrapolation (i.e. prediction), and is much more subject to corruption > by noise. > > > =A0 Since the ADC is sampling some valuable medical diagnostic data(ECG=),> > i guess its not a good practise to do upsampling. > > Maybe. =A0If it's so dang valuable, why can't you just sample the ADC at > the right frequency? > > I wouldn't expect ECG data to have much frequency content above a few > hundred Hz. =A0If this is so, then you should be able to resample it > fairly cleanly. > > Finally -- what are you going to _do_ with it at your 16kHz? =A0If it's > some analysis, then perhaps that analysis will work fine after > resampling, even if the result wouldn't look perfect to a cardiologist. > > You should find out what the analysis is, and whether it will tolerate > resampled data. =A0You should also find out what the characteristics of > the signal you're playing with -- if it's already way oversampled, then > doing a bit of interpolation on it will probably not hurt at all. > > > =A0 Is there anyway to do with just downsampling or do I need to sample > > at even higher frequencies for downsampling to be applied? > > Yes. =A0In fact, you've already been told -- sample rate conversion, whic=h> uses polyphase filtering. =A0There's not need to actually upsample then > downsample -- polyphase filtering gives you the result of that > upsample/downsample combination, without forcing you to actually do all > the work. > > > Another option is to use 200 Khz CNV frequency and do the sampling for > > just 192 KHz(192k samples) and for the rest 8 Khz send some junk > > control word to the ADC in the TX_interrupt handler. Once it's > > elapsed(8k samples), again come back to the previous control words. Is > > this feasible? > > If you're planning on doing what I think you are, it would mess up the > signal worse than sample rate conversion. > > > Can we keep some kind of count in the interrupt > > handler(ISR) that lets us know that 192k and 8k samples have been > > sampled? > > > My CNV is 200 Khz and the SCLK is 8 Mhz. > > -- > > Tim Wescott > Wescott Design Serviceshttp://www.wescottdesign.com > > Do you need to implement control loops in software? > "Applied Control Theory for Embedded Systems" was written for you. > See details athttp://www.wescottdesign.com/actfes/actfes.htmlThanks a lot for the support that i have got in this forum. It was really helpful and a good learning experience for me. I have decided to sample only 10 channels of ADC since the Blackfin can exactly generate the CNV pulse of 160 kHz so that i can get the exact 16kHz sampling frequency per channel. @Tim Wescott : Yes, I will do the analysis as you have told. I am just a beginner so , i dint feel that i had to go deep into that part mostly because i thought i won't understand those things. Regards Shafi
Decimation
Started by ●April 5, 2011
Reply by ●April 7, 20112011-04-07
