I recently implemented fast convolution filtering for the "tools" portion of KISS FFT ( http://sourceforge.net/projects/kissfft ) I've seen a few realizations of the overlap-scrap (aka overlap save) method. They all have the scrapped output samples at the beginning of the output buffer. Those realizations require an additional buffer copy to write continuous output. I found a way to get around this buffer copy. After zero padding the impulse response up to Nfft, rotate the buffer left by Nh - 1 samples. The junk samples end up at the end of the ifft'd buffer. Thus the IFFT can use the output buffer for filtering as its output buffer. Only Nfft-Nh+1 of those samples are fit for consumption, but the scrap samples can be overwritten by the next chunk. I searched around a little bit, but couldn't find mention of this technique anywhere. Is this new, or is it so obvious as to not warrant description? - Mark Borgerding PS. Here's some octave (Matlab clone) code that I used for proof-of-concept. If you want a working version, see kiss_fastfir.c in the latest version of KISS FFT. function maxabsdiff=tailscrap() % test code for circular convolution with the scrapped portion % at the tail of the buffer, rather than the front % % The idea is to rotate the zero-padded h (impulse response) buffer % to the left nh-1 samples, rotating the junk samples as well. % This could be very handy in avoiding buffer copies during fast filtering. nh=10; nfft=256; h=rand(1,nh); x=rand(1,nfft); hpad=[ h(nh) zeros(1,nfft-nh) h(1:nh-1) ]; % baseline comparison y1 = filter(h,1,x); y1_notrans = y1(nh:nfft); % fast convolution y2 = ifft( fft(hpad) .* fft(x) ); y2_notrans=y2(1:nfft-nh+1); maxabsdiff = max(abs(y2_notrans - y1_notrans)) end
fast convolution overlap-scrap filtering with scrap at end
Started by ●January 31, 2004
Reply by ●February 3, 20042004-02-03
bump. Mark Borgerding wrote:> I recently implemented fast convolution filtering for the "tools" > portion of KISS FFT ( http://sourceforge.net/projects/kissfft ) > > I've seen a few realizations of the overlap-scrap (aka overlap save) > method. They all have the scrapped output samples at the beginning of > the output buffer. Those realizations require an additional buffer copy > to write continuous output. > > I found a way to get around this buffer copy. After zero padding the > impulse response up to Nfft, rotate the buffer left by Nh - 1 samples. > > The junk samples end up at the end of the ifft'd buffer. Thus the IFFT > can use the output buffer for filtering as its output buffer. Only > Nfft-Nh+1 of those samples are fit for consumption, but the scrap > samples can be overwritten by the next chunk. > > I searched around a little bit, but couldn't find mention of this > technique anywhere. Is this new, or is it so obvious as to not warrant > description? > > - Mark Borgerding > > > PS. Here's some octave (Matlab clone) code that I used for > proof-of-concept. If you want a working version, see kiss_fastfir.c in > the latest version of KISS FFT. > > function maxabsdiff=tailscrap() > % test code for circular convolution with the scrapped portion > % at the tail of the buffer, rather than the front > % > % The idea is to rotate the zero-padded h (impulse response) buffer > % to the left nh-1 samples, rotating the junk samples as well. > % This could be very handy in avoiding buffer copies during fast filtering. > nh=10; > nfft=256; > > h=rand(1,nh); > x=rand(1,nfft); > > hpad=[ h(nh) zeros(1,nfft-nh) h(1:nh-1) ]; > > % baseline comparison > y1 = filter(h,1,x); > y1_notrans = y1(nh:nfft); > > % fast convolution > y2 = ifft( fft(hpad) .* fft(x) ); > y2_notrans=y2(1:nfft-nh+1); > > maxabsdiff = max(abs(y2_notrans - y1_notrans)) > > end >
