Hi Sharc fellows, I'm stuck with a problem which is trivial for those who've done it. However, I don't find documentation which helps me. Given, I want to multiply two stored variables with two constants from a table (all are floating point 40bit) , then sum the results and store the new result for further use. Retrieved from the working 32bit version, I'd guess something like, but neither the initialization nor the calculation or storage works like expected. What am I missing? Bernhard .precision=40; .section/pm seg_pmda; .var constant[2]=1.23,2.34; .section/dm seg_dmda; .var storage[3] = 1.11,2.22,0; .section/pm seg_pmco; routine: push sts; bit clr mode1 RND32; i8 = constant; i0 = storage; f0 = dm(i0,1); f8 = pm(i8,1); f1 = f8 * f0; f0 = dm(i0,1); f8 = pm(i8,1); f2 = f8 * f0; f3 = f1 + f2; dm(i0,0) = f3; pop sts; routine.end:
Handling of 40bit values in Sharc
Started by ●January 29, 2004
Reply by ●January 30, 20042004-01-30
Bernhard Holzmayer wrote:> Hi Sharc fellows, > > I'm stuck with a problem which is trivial for those who've done it. > However, I don't find documentation which helps me. > > Given, I want to multiply two stored variables with two constants > from a table (all are floating point 40bit) , > then sum the results and store the new result for further use. > > Retrieved from the working 32bit version, I'd guess something like, > but neither the initialization nor the calculation or storage works > like expected. What am I missing?Have you declared the segments as 40bit data memory in the LDF? And are you using 40bit data access on PM and DM (by setting the IMDWx bit in the SYSCON)? Last, did you clear the RND32 bit in the MODE1 register? Regards, Andor
Andor wrote: Sorry, I'm out of work for the week-end now. Nevertheless, thanks for your answer.> Have you declared the segments as 40bit data memory in the LDF?I'm not sure if I did it right. I'll show you my entries on Monday (no access in the moment!)> And are you using 40bit data access on PM and DM (by setting the > IMDWx bit in the SYSCON)?No, I wasn't aware of this register. maybe it's the key. I'll check this!> > Last, did you clear the RND32 bit in the MODE1 register?Yes, as you see in my example. Bernhard
Reply by ●February 4, 20042004-02-04
Hi Andor,
meanwhile I started from scratch, trying to set 40bit processing up.
I succeeded to read data from 40bit internal ram, get it into
registers and out again into 40bit IRAM.
Still, working with external SDRAM fails.
Below is a short portion of sample code which should contain
everything necessary. Would you please have a look on it,
if anything obvious is wrong??
My LDF file contains appropriate segments like this:
In the MEMORY section, I marked it as 48bit
in the SECTIONS section, I marked it as 40bit and linked correctly.
The Expressions-window of the VisualDSP-IDDE shows the correct
initial values with 40bit precision, thus it seems as if the mapping
were ok.
#include "def21161.h"
.precision=40;
.section/pm seg_pm40;
.var _ivektor = 0.1;
.var _isummand = 0.1;
.section/pm seg_xpm40;
.var _xvektor = 0.1;
.var _xsummand = 0.1;
.global _main;
_main:
r0 = IPACK0|IMDW0X|IMDW1X; r1 = dm(SYSCON);
r0 = r1 or r0;
dm(SYSCON) = r0;
bit clr MODE1 RND32;
i8 = _xvektor; i9=_xsummand; m8=0;
tag:
lcntr=5, do next1 until lce;
px = pm(i8,m8);
r0 = px;
px = pm(i9,m8);
r2 = px;
f0 = f0 + f2;
px = r0;
next1: pm(i8,m8) = px;
i8 = _ivektor; i9 = _isummand;
jump tag;
jump _main;
_main.end:
The program does essential initialization of SYSCON, MODE1
registers, then tries to increment an external RAM cell (_xvektor).
This fails.
Then it does the same with a cell in internal RAM, and succeeds.
Bernhard
before sending to the above email-address:
replace deadspam by foerstergroup and de instead of com
Reply by ●February 6, 20042004-02-06
Bernhard Holzmayer wrote:> Hi Andor, > > meanwhile I started from scratch, trying to set 40bit processing up. > I succeeded to read data from 40bit internal ram, get it into > registers and out again into 40bit IRAM. > Still, working with external SDRAM fails.Bernhard, before we proceed: are you working on the 21161N EZ-Kit? Regards, Andor
Andor wrote:> Bernhard Holzmayer wrote: >> Hi Andor, >> >> meanwhile I started from scratch, trying to set 40bit processing >> up. I succeeded to read data from 40bit internal ram, get it into >> registers and out again into 40bit IRAM. >> Still, working with external SDRAM fails. > > Bernhard, > > before we proceed: are you working on the 21161N EZ-Kit? >Yes.> Regards, > Andor
Reply by ●February 9, 20042004-02-09
Bernhard wrote:> Hi Andor, > > meanwhile I started from scratch, trying to set 40bit processing up. > I succeeded to read data from 40bit internal ram, get it into > registers and out again into 40bit IRAM. > Still, working with external SDRAM fails. > > Below is a short portion of sample code which should contain > everything necessary. Would you please have a look on it, > if anything obvious is wrong??I don't see anything wrong at first glance. Make sure you have set up the SDRAM for 48bit access and not for 32bit access (check out the 21161N and the EZ-Kit manuals for the relevant registers). Regards, Andor
Reply by ●February 10, 20042004-02-10
Andor wrote:> Bernhard wrote: >> Hi Andor, >> >> meanwhile I started from scratch, trying to set 40bit processing >> up. I succeeded to read data from 40bit internal ram, get it into >> registers and out again into 40bit IRAM. >> Still, working with external SDRAM fails. >> >> Below is a short portion of sample code which should contain >> everything necessary. Would you please have a look on it, >> if anything obvious is wrong?? > > I don't see anything wrong at first glance. Make sure you have set > up the SDRAM for 48bit access and not for 32bit access (check out > the 21161N and the EZ-Kit manuals for the relevant registers). > > > Regards, > AndorThanks Andor, for checking. Yes, that's it, a wrong initialization of the SDRAM while loading the coefficients. I didn't see it at first glance, because the emulator hides the effect: after resetting and before reloading code and initialization values, it switches back to 32/48bit mode, thus initialized values are in wrong locations. However, when loading from Flash, it works bc. I'd inserted the SYSCON modification into the prom loader. Removing the flag (Target options...) which resets the processor, made the emulator behave as it should. I should have known, bc. I dealt with the issue one year ago, ... Bernhard
Reply by ●February 11, 20042004-02-11
I should have added, that my confusion started when I watched wrong values while checking an algorithm's implementation. I guessed that these wrong values must have their origin in the area of 40bit processing. Then I got trapped in this initialization stuff. However, although these issues are solved, I still end up with errors during the algorithm. While single stepping through my code, yesterday, I could see (in the emulator windows) that different registers change their values without obvious reason. Concerned registers were i0, i8, m0 (and maybe others which I wasn't aware of). The registers weren't actively used, I mean, they didn't participate in the current or previous/next commands to process. So, it's certainly not an issue of contents of Lx or Bx registers. This might be an explanation why my algorithm did fail: when I fetched data from memory with a wrong index or modifier register, I'd have certainly ended up with messy data. My question: Is there anybody out there who suffered/suffers from the same problems with Sharc DSPs / EZ-Lite boards ? Are there any experiences and/or maybe solutions? I wonder if it's a hardware issue, maybe my USB cable is too long, or the ground potentials of the different connections raise instabilities. Any ideas welcome. Bernhard
Bernhard Holzmayer wrote: ...> While single stepping through my code, yesterday, I could see (in > the emulator windows) that different registers change their values > without obvious reason. > Concerned registers were i0, i8, m0 (and maybe others which I wasn't > aware of).I have an 21161N EZ-Kit and never had any such problems. Single stepping a real-time system is not trivial. Perhaps some interrupt routine modified those registers? Regards, Andor
