C6711 and THS1206
Started by Juan A. Torres-Rosario January 29, 2004
Hi,
I have recently adquired a THS1206 Daughter Card. I have a C6711 DSK.
I know
about DSP (theory) but not that much about hardware. I tried to look
for
programs or information on the web, but I cannot find programs for the
THS1206 and the C6711 DSK. Can someone send me a demo program in Code
Composer where a C6711 and the THS1206 is used?
Att.,
On 29 Jan 2004 06:34:11 -0800, Juan A. Torres-Rosario wrote:
> Hi, > > I have recently adquired a THS1206 Daughter Card. I have a C6711 DSK. > I know > about DSP (theory) but not that much about hardware. I tried to look > for > programs or information on the web, but I cannot find programs for the > THS1206 and the C6711 DSK. Can someone send me a demo program in Code > Composer where a C6711 and the THS1206 is used?
The easiest way to get started is having the CCS data converter plugin generating your code. You can download the latest version at: http://www.ti.com/sc/docs/tools/msp/dataconv/plug_in.htm I could also send you some example using the drivers generated by the plugin via mail, if you want.... best regards, Gebhard
Gebhard Haug <ghaug@compuserve.com> wrote in message news:<1kg5i7sdfgy9p.55k66bthx78k$.dlg@40tude.net>...
> On 29 Jan 2004 06:34:11 -0800, Juan A. Torres-Rosario wrote: > > > Hi, > > > > I have recently adquired a THS1206 Daughter Card. I have a C6711 DSK. > > I know > > about DSP (theory) but not that much about hardware. I tried to look > > for > > programs or information on the web, but I cannot find programs for the > > THS1206 and the C6711 DSK. Can someone send me a demo program in Code > > Composer where a C6711 and the THS1206 is used? > > The easiest way to get started is having the CCS data converter plugin > generating your code. You can download the latest version at: > > http://www.ti.com/sc/docs/tools/msp/dataconv/plug_in.htm > > I could also send you some example using the drivers generated by the > plugin via mail, if you want.... > > best regards, > Gebhard
Hi Gebhard, I have tried generating the Code with the CCS data converter plug-in, which seemed pretty straight forward. Here is an example of the parameters I used for my THS1206: Address: 0xA0020000 Data Shift: 0 Interrupt: Ext_Int 4 Channels: Autoscan 4 Sampling Frequency: 100kHz Mode: Normal I think my problem strives in constructing the DSP/BIOS File (*.cdb) and how to setup the main function to get the DSP and the THS1206 running. Any example of projects you have used with the THS1206 you can send me will be greatly appreciated. My e-mail is trutano@yahoo.com Att., Juan A. Torres-Rosario
